Does anyone know how to disconnect the fuel line connectors in the engine bay so I can purge the lines after a fuel filter change?
![]() Join Date: Oct 2006
So press down on the triangular tank and pull apart; yes?
regards Blue |
Lift up the triangle part. Put a small screwdriver into the fitting on the opposite side to clear the bottom of the connector from the pipe ridge. Pull the connector off.
