This may seem like a stupid question but here goes:
When the timing kit and water pump is replaced , do they remove the motor or ? I have had mine replaced by a Ford service centre and have had a Tyrade of issues with the vehicle since then Cheers |
The diesel im guessing?
No you do not remove the engine. Its a little fiddly but you dont have to remove a large amount of components What kind of issues have you had?
BA pursuit maintance/build thread |
There was a broken wiring harness (the clip was broken causing surging and stalling ) . And car generally just running like a heap of crap . Followed by a split leak off pipe (which in turned cause a small fire) .
