Old 03-11-2018, 03:36 PM   #1
fobzee
Default jack stand position - mk7 fiesta st
Hi
I had to change the brake pads on my mk7 FiST the other day so I jacked the car up using the normal jack first and then used a trolley jack on the blue spots in the pic , was that a safe place ?
car looks and drives fine just want to make sure if I need to again in the future its ok
https://i.imgur.com/b3KWbS4.jpg
fobzee is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2018, 01:30 AM   #2
GTLEGEND
Default Re: jack stand position - mk7 fiesta st
From the workshop manual, it should only be jacked from the side points as per the attached.
WZ Jacking Points.doc
Old 04-11-2018, 11:09 AM   #3
fobzee
Attachment 100361
thanks, I'll stick to them next time. Wouldn't have done any damage though? drives/looks fine
a shame there's no central spot it would make it so much easier
Old 04-11-2018, 12:41 PM   #4
GTLEGEND
Should not have if you do it once here and there, just don't make it a habit!
Old 24-03-2021, 03:53 AM   #5
phez
Where did you put the jack stands? You mention the jack points
phez is offline   Reply With Quote Multi-Quote with this Post
