Old 06-01-2022, 12:03 PM   #1
NPS
Default DPF cleaner
Hi All, Happy New Year to everyone. 2015 mondeo trend wagon when and how to use DPF cleaner? Noel.
NPS is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2022, 12:13 PM   #2
Gabs9174
Default Re: DPF cleaner
Hi Noel
Happy New Year, please correct me if I am wrong but you can’t use a dpf cleaner as such. You have to take it into a workshop to clean it. I have also been told if you regularly take your car out on the freeway for about 30 mins it keeps your dpf in good shape
Gabe
Sent from my iPhone using Tapatalk
Gabs9174 is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2022, 04:50 PM   #3
NPS
Thanks for that Gabe.
Old 07-01-2022, 01:18 PM   #4
simon varley
Technical Contributor: For members who share their technical expertise. - Issue reason: Bringing sanity to the Everest threads.
drive it hard and it will burn off itself. If it still shows blocked, then the dealer can force a burn. If it's burnt but full of ash then I'm afraid a replacement will be needed.
simon varley is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2022, 12:00 PM   #5
NPS
Thanks Simon, its not showing anything at the moment was trying to catch it before it did. Noel
Old 11-01-2022, 10:05 AM   #6
mourati
mourati's Avatar
Option 1 if you have a copy of forscan and the OBDlink / EELM327 you can run the program yourself. Not overly complicated to run through the menus and forscan has a link that advises users.
Option 2 is ongoing preventative option is to drop this in your fuel tank every so often - see link: https://www.liquimoly.com.au/2729-di...lter-anti-clog
Option 3 if you are based in Melbourne is I have a contact head mechanic from Ford that operates on the side. He pressure washes these without the need to replace them. They clog up if you don't allow them to heat up often enough.
Hope this helps
mourati is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2022, 04:25 PM   #7
NPS
Thanks Mourati, will give opt2 a try. Noel
Old 13-01-2022, 10:38 AM   #8
NPS
Hi Mourati, sent a PM but it didn't go through. The bloke in option 3 is that the one you sent a while back in Glenroy? Noel
