Old 11-03-2022, 10:11 AM   #1
zlcrazy
zlcrazy's Avatar
Question Towbars
Hi all,
My AU2 Fairmont Wagon has a 2300kg Hayman and Reese tow bar. The sticker says towing capacity 2300kg, towball download 120kg.
Every tow bar I've had on my Falcons weather it be genuine Ford or Hayman Reese have always been the 10% rule of the tow capacity.
I'm just wondering why this one states only 120kg? Anyone know?
Thanks
James
2005 BAII Falcon XR6T - Velocity Blue
Factory Options; Sunroof, Premium Sound, Plexus Blue Cloth Trim.
Genuine Accessories; XR Scuff Plates, XR Blue Carpet Mats, Boot Liner, Cargo Net, Aux Audio Input (Boosted Type), Front & Rear Mudflaps, Headlamp Protectors, Bluetooth and Mobile Phone Holder.
[B]2000 AU2 Fairmont Wagon - Congo Green
Factory Smart Bullbar, Hayman Reese Heavy Duty 2300kg Towpack and Front and Rear Mudflaps.
zlcrazy is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2022, 11:30 AM   #2
Crazy Dazz
Default Re: Towbars
Is that on the one sticker?
It should definitely be 230, but maybe it has a different tongue fitted?
Old 11-03-2022, 12:25 PM   #3
zlcrazy
zlcrazy's Avatar
Default Re: Towbars
Yeah the sticker on the inside of the drivers door.
Old 11-03-2022, 02:31 PM   #4
pcman
Default Re: Towbars
not sure about au, but ef/el wagons had 2 different 2300kg towbar, one was 120kg ball weight the other 230kg, ive had both the only difference i could see was where the hitch came out, either through the factory bumper hole, or under the bumper
pcman is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2022, 06:51 PM   #5
Crazy Dazz
Default Re: Towbars
If that's a genuine HR sticker, it should show the part number for the Towbar, and tongue if seperate.
Is it the typical Square "Hayman Reese" removable tongue?
Or is it a bolt on tongue?
Old 11-03-2022, 06:53 PM   #6
Crazy Dazz
Default Re: Towbars
I thought it was the square tongue style that went through the bumper,
and the older style fixed tongue that came up from underneath.
Old 11-03-2022, 07:48 PM   #7
hayseed
Default Re: Towbars
I'd ring Hayman Reece & ask for the Oldest Bloke in the Building.......!!!
hayseed is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2022, 10:18 PM   #8
zlcrazy
zlcrazy's Avatar
Default Re: Towbars
Thanks for the replies guys.
Mine is the 50mm hitch with removable tongue that comes thru the bumper opening if that helps...
Old 12-03-2022, 09:59 AM   #9
Itsme
Itsme's Avatar
Default Re: Towbars
It has been known at times for ford to restrict towing capabilities with some models regardless as to what the tow bar rating shows, one such fine example is the Ford FG with manual gear box fitted with 2300kg tow bar being restricted to towing weight of 1600kgs.
In zlcrazy situation of having the genuine ford label stating 120kgs ball weight attached is a legal requirement that must be followed, just means he must balance his 2300kg load to conform to the label.
Obviously his model is not designed for a heavier ball weight.
Old 12-03-2022, 02:06 PM   #10
pcman
Default Re: Towbars
nope, both are 50mm square removable hitch
Old 12-03-2022, 03:04 PM   #11
prydey
Rob
prydey's Avatar
Default Re: Towbars
If its a genuine Ford sticker, unfortunately, that is your limit, unless there is something in the owners handbook that states a different figure if a HD hitch is used.
I'd be a bit wary of towing 2t with only 5% ball weight.
UA2 TREND 4WD BI TURBO
Old 12-03-2022, 06:26 PM   #12
zlcrazy
zlcrazy's Avatar
Question Re: Towbars
Hi all again,
No its not a Genuine Ford towbar it's a Hayman and Reese towbar.
The sticker is in the driver's door jam
James
Old 12-03-2022, 06:28 PM   #13
prydey
Rob
prydey's Avatar
Default Re: Towbars
Hi all again,
James
Is the sticker a Ford sticker, or has it been put there by Hayman Reese?
Old 12-03-2022, 06:49 PM   #14
mad2
Regular...with metamusal
Default Re: Towbars
Hi all again,
James
is the sticker as this
or as this?
Old 12-03-2022, 08:02 PM   #15
zlcrazy
zlcrazy's Avatar
Default Re: Towbars
or as this?
The sticker is Hayman Reese as per the second pic except stating 120kg download
Old 12-03-2022, 08:07 PM   #16
prydey
Rob
prydey's Avatar
Default Re: Towbars
I would have thought it would just be a matter of upgrading the hitch?? Maybe contact Hayman Reese.
Old 12-03-2022, 08:25 PM   #17
mad2
Default Re: Towbars
i agree, best way to find out.
