#781 | |||
#782 | |||
Barra Turbo > V8
The ebay link above OOS. Sorry. Its for FG wiper bolt covers.
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+ Tuned by LS Tuning and Performance -2022 Hyundai Tucson Highlander Diesel N Line Last edited by DJM83; 29-04-2022 at 11:16 AM. |
#783 | ||
I may have found one, its on its way to me with some other parts, let you know when I get it.. then we can go from there..
#784 | ||
#785 | ||
#786 | ||
Regular...with metamusal
![]() Join Date: Oct 2009
Hi Legend
![]() as usual more questions for you [if you don't mind] & this time it's not about wiring looms ![]() ![]() all i can tell you is it came out of an FG front passenger seat. ![]() coupla better pics - of the back with the sticker removed. ![]() of the front. ![]() ![]() they are the only 'labels' i could see on it. i'm only wondering what it is as i have no idea. not sure why it has 3 different numbers on the item [excluding the ford sticker - on the 'front' it has 307504 2007.06.15, on the back to the left [& hard to read] it says 307506 2007.06.15 [or maybe 307508 2007.06.15 ] & 307505 2007.06.15 hidden behind the sticker Thanks. |
#787 | |||
There are no Ford identifying numbers that I can see and have no idea what that is either. Futuris was the supplier of the seat, but are no longer open as a company. Maybe someone who has a seat out and disassembled can assist as I don't think that is a part that was serviceable? |
#788 | |||
*SILVER SERVICE PILOT*
![]() ![]() Join Date: Jul 2006
BUILD THREAD
https://www.fordforums.com.au/showth...71#post6891271 2006 Lightning Strike BF Fairlane Ghia...HIS 2024 Titan Grey Hyundai Tucson Highlander...HERS |
#789 | ||
That would be plausible, about the only electronic part on an FG passenger seat. That was called Air Bag Body Weight Sensor part number 8R2Z14B422A, but I cannot find a decent image of that part..
#790 | |||||
see what happens. thanks for looking it up for me tho ![]() Quote:
#791 | ||
#792 | |||
in the FG WSM 700-0062 [501-20B-00-1 Occupant Restraints - Passive] it mentions a mat sensor @ C-358. so i think that's it. |
#793 | ||
XB,XF,ZL,EA,EL,BA,SY,SZII
G'day GT. What sort of price can you do for the following bulk consumables (say 10-packs) including shipping please?...
Engine oil filter AFL-101 (yeah, I know, there are plenty of these on eBay) Engine oil WSS-M2C929-A 5 Litre (haven't seen these on eBay) |
#794 | |||
The best I can get AFL101 is $13 each and it does not matter if you buy 1 or 10 the price is the same. eBay prices in this case is below cost that my contact gets for. You are better to get the ones on ebay for less than $10. Genuine oil that meets that spec now has a part number of AX05W30A6LFD and is $80 for 5L. I think there are some bit cheaper on eBay. Freight will depend on size and weight of package. One air filter would be around $10, box of 10 guessing around $15. Oil due to its size and weight would be around $20 but that is a pure guess until I have exact dimensions/weights etc. GT |
#795 | ||
Much obliged GT.
Double that amount for freight would be okay by me for 40kg of oil, but WSS-M2C929-A only cost about $30 for 5L when I last bought it a year ago, so I might see if I can find out what's going on with that. Thanks for confirming the situation with AFL-101 filters. Bam |
#796 | |||
#797 | ||
Hi GTLEGEND
Can you source genuine FPV front floor mats? |
#798 | ||
#799 | ||
![]() Join Date: Jun 2007
They do come up on ebay every couple of months but you'll need to get your wallet out, usually sell for around 1500-2000.
I've had Matcraft in Perth do replica floor mats for all my cars, their work is very good. Maybe worth swinging them a message.
Proud owner of the ugliest Ford ever made Last edited by fordomatic; 16-05-2022 at 10:50 AM. |
#800 | ||
#802 | |||
Ford part WSSM2C929A5L was $30-odd for 5L of 5W-30 semi synthetic engine oil that met Ford specification WSS-M2C929-A. That was the exact spec that SY to SZII Territory I6 engines were designed to use, and presumably BF to FG-X Falcon I6 engines too. I can't find any remaining stocks of it anywhere. I suspect that it might have been Mobil Formula S supplied in a Ford container. Ford part AX05W30A6LFD is $80-odd for 6L of 5W-30 full synthetic engine oil. I can't find any information about the specs it meets, however it is evidently not really a straight replacement for WSSM2C929A5L, and "recommended for" is not the same thing as actually meeting a spec. It'd be handy if someone with a container could confirm what's written on the label. |
#803 | ||
#804 | |||
#805 | |||
Thanks GTL The air cleaner diagram isnt clear when i view it but it looks as though it may be the small plate and screws that i can see to the left of the air filter in the exploded view. As far as the other diagram it is a little clearer but i am talking about what is under the 2 CIRCULAR holes that can be seen in part 8C382 on the left and right hand side. Approx 30mm diameter. cheers |
#806 | |||
As for the other part, not really sure what you are referring to, going to need a picture to clarify sorry. FG2 Air Cleaner.PNG |
#807 | ||
G'day GT good sir,
Would you be able to advise what the part number is for a 2004 Ford Falcon 5.4L 3v (Barra 220) power steering pressure switch? Its got the green insulator. Thanks!
~~~~~~~~~~~~~~ Rides (past and present) Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m) AFF motto - If contrary views trigger, please use ignore button. ![]() |
#808 | |||
I will try and do some research on whats underneath the cowling. cheers. |
#809 | |||
I have the 5.4 power steer switch the same for 3V or 4V engines as 94BP3N824AA, can get them for $130 plus postage. Gt |
#810 | |||
9A646: Part number 811J9A646AA $70 + postage. HS1: Part number W708825S440 $6 each + postage. HW1: Part number not listed. Have to chase. HM1: Part number not listed. Have to chase. Get back to you as soon as I can find out. Gt |
