04-01-2008, 05:59 PM | #1 | ||
Formerly MR BAXR6t
Hey guys
I have this noise when the car starts, like a sort of repeating knocking/tonking noise for like 2 seconds then u dont hear it again, until the next time u start it. Any idea wat it could be? cheers
Current car 94 ED Fairmont 5L in Burgundy Fords ive owned- 2010 FG XR6 5 speed auto in Mystic 81 XD S-Pac 302c 4sp manual 78 Yellow TE Cortina Wagon 4.1L 92 Green EB Fairmont GT replica 01 Black AU XR8 II Manual 04 Rapid BAII XR6T 220rwkw 04 Mandarin BA XR6T 247rwkw 07 BF II XR6T 385rwkw 1980 ZJ Fairlane 302c |
04-01-2008, 07:28 PM | #2 | ||
not here much anymore
How old is your oil and what grade is it?
RAM 1500
04-01-2008, 08:01 PM | #3 | ||
Formerly MR BAXR6t
just did the service on it today. Its nulon 15-50
04-01-2008, 08:27 PM | #4 | ||
Smile
lifters ?
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
04-01-2008, 08:46 PM | #6 | ||||
BOSS Pilot
Black BAII XR8 Ute Blue SY Territory Ghia Quote:
04-01-2008, 08:48 PM | #7 | |||
Formerly MR BAXR6t
04-01-2008, 09:28 PM | #8 | ||
14.915 @ 151 KPH
hey, if its only for 2 secs that will be the time it takes for the oil pressure to build up. if it does it while warm id be worried
:evil3: 96 EF2 Futura I6 Auto :evil3: EL XR Front, 16 inch Tickford's, Superlow's Front/Rear with Monroe GT Sport's : , XR6T Snorkle/Fram Filter, 4499's/Hi Flow Cat/2.5 inch Redback, 4.11's/LSD, 5% Tint, Sony Head Unit/ 6 1/2 Inch 190w Speaker's : 14.915 @ 151 kph 60' 2.254 : |
04-01-2008, 09:40 PM | #9 | ||
Falcon Unbelievable!
Might be worth checking to see if the exhaust/manifold is touching the sump at startup. I had this happen to my AU annoyed the heck out me, only ever happened at start up and not all start ups. Turns out when it had heat in it, it moved away from the sump. Might be something completely different to this but if it helps relieve some frustration then its worth it.
04-01-2008, 11:13 PM | #10 | ||||
BOSS Pilot
04-01-2008, 11:41 PM | #11 | ||
Audi S3
sure its not ticking? like loose headers?
05-01-2008, 02:00 AM | #12 | ||
Formerly MR BAXR6t
Na its not ticking, more a clocky noise. But i changed the oil today nad drove it tonite and didnt seem to do it??
05-01-2008, 02:22 AM | #13 | |||
Back to Le Frenchy
Mine had an odd knocking noise at cold start up when I was using a Z9 oil filter. Ever since I started using a Z89A (stubby Z9, about half the length) it hasn't been there. Btw I've found that mine actually runs better on Nulons 10w synthetic oil.
06-01-2008, 02:48 AM | #14 | ||
My non-XR8 AU V8 does a similar thing everytime I change the oil. Takes about a week and it stops doing it until the next time the oil is changes. When it was still in warranty I asked the dealer about it everytime I picked it up from the service and they just said it's within normal tolerences. As it's done it since 2002 I suppose it's not terminal.
I might try the Z89A trick next oil change though? (oil gets changed every 7500km) |
06-01-2008, 08:18 PM | #15 | |||
Formerly MR BAXR6t
06-01-2008, 11:17 PM | #16 | |||
220's run the Z89 cos of the oil cooler, 200's run Z9's.
RAM 1500
06-01-2008, 11:30 PM | #17 | ||
Formerly MR BAXR6t
i forget wat filter i used was. But apparantly there are 2 different one. One for xr8 with oil coolers and one with out. ! is almost twice as big as the other. Now i have the shorter of the 2 on my 200kw and im not sure which one it is? But its the same size filter that was on it before and the noise has stopped?? Does any one know what filter i may have??
06-01-2008, 11:38 PM | #18 | |||
Looking for clues...
In layman's terms, the bigger the filter, the longer you can leave it in between changes (a bigger filtration area to collect crap). It might take a little more oil to keep the levels up, but unless it's protruding on exhaust pipes because of the extra size, it shouldn't be a problem. |
06-01-2008, 11:42 PM | #19 | |||
swanny i get what youre saying but personally i always use the filter specified, but each to their own.
RAM 1500
06-01-2008, 11:46 PM | #20 | ||
Formerly MR BAXR6t
its not gunna do any damage leaving the one on there now yea?
06-01-2008, 11:47 PM | #21 | ||
Austin, no probs. just looking at the layman's way of thinking.
06-01-2008, 11:50 PM | #22 | |||
mr auxr8, no problems with leaving it on.
RAM 1500
07-01-2008, 01:51 AM | #23 | |||||
Back to Le Frenchy
07-01-2008, 08:05 PM | #24 | ||
as a mech i can be sure that noise your hearing is your crank bearings not getting oil pressure as soon as they should, with ford engines make sure you use a good quality oil filter preferably genuine as they have a valve in them that prevents oil loss out of filter when engine is off. my 6cyl au did the same thing when i bought it and it had one of those cheap and nasty oil filters on it, changed oil and put genuine filter on and no more probs cheers..
13-11-2022, 10:36 AM | #25 | ||
When I start my g6e I have this ticking ratchet noise when it’s starting up for few seconds only when cold after that when she is warm no problem any ideas sound coming out near gauges on dash
13-11-2022, 11:07 AM | #26 | |||
Former BTIKD
https://www.fordforums.com.au/forumdisplay.php?f=350
