24-11-2022, 02:27 PM | #5 | ||
Hey Minerva, I can see how you want to go in from the side, I think it would be a nightmare and very difficult getting the bushes in and out if not impractical with the ridge in the middle of the bushes. You’ll want to drop the sub frame. Mark its location on the body with a paint pen before loosening the bolts if you dont have the locator pin for reinstallation. It’s a good opportunity to renew your suspension if needed and inspect the top of the subframe/clean the p/s rack. The manual referenced above is useful and the haynes manual has the torque specs. Id go for energy suspension bushes from rockauto usa. Using 2003 dohc 2.0 zetec for the parts selection. Your chasing the 21 mm energy suspension ones but there are ac delcos there. Don’t be concerned that they are cheap to buy to buy (USA is super competitive in pricing for parts) You can get harder ones from burton power in the UK. But you’re looking at maybe five times the cost shipped vs Rockauto. Be carful buying other Left hand drive parts if it is aircond compressor or ac pulley related as well. Otherwise matching part nunbers is safe and motorcraft parts are really inexpensive and available.
Im doing a H+R 24 mm bar soon and plan to plug up the ps rack with silicone plugs and install my sway bushes/bar with it on a flat surface and leave my ps rack on the subframe. My car is ok for rust so I’ll just clean the ps rack and sub-frame and maybe hit areas with cold gal paint if needed. I can post a vid to tiktok if you want to see how I’m disassembled and do it with the car on jackstands. Only going through focus threads now so sorry if my info is late. |
