Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member. |
#1141 | ||
G'day,
Is it at all possible to get the overhead clocks that were fitted to BF GTs with dual zone ICCs? I've hunted high and low. If not, is there at least a part number for them floating around? (I understand some Territorys had them as well?) |
#1142 | ||
Merry Christ-mas GT legend, and all the thread starters, posters, and responders to help solve our ford life issues, no matter what day of the year it it ❤️
Current 2009 FG GTP Sold 2003 boss 260 xr8 daily driver 1991 eb1 xr8 once a year driver, factory cassette player |
3 users like this post: |
#1143 | |||
The assembly is different to the Territory. |
#1144 | ||
9 users like this post: |
#1145 | |||
Worn-out Ford Tech
As mentioned by @GTLEGEND they're no longer available. However, Tom at GTP Reproductions on FB has mentioned that he might be looking to reproduce them one day, no ETA though at this stage. |
#1146 | |||
Thanks. I actually tripped over their FB page not long after coming here. Hopefully they go ahead with it, it's a frustrating quest. The original owner of mine had a new windscreen put in and they broke the clock. Is there a guide for pulling one off the roof and pulling it apart anywhere you know of? |
#1147 | |||
Cheers for that. A part number may at least help in the search. So the housing of a Territory one is different? Or the internals are? Or the whole thing? I was kind of hoping I could get hold of one and make something good out of it and my broken one. |
#1148 | ||
WT GT
![]() Join Date: Jan 2006
I’ve never seen the roof mounted clock, so don’t know what it looks like, but is this what you’re looking for?
https://www.ebay.com.au/itm/16508261...mis&media=COPY |
#1149 | |||
Falcon: Clock assembly: BA2T15000A Clock wiring: BA2T15026A Rear Cover: BA2T15C000A Digital Clock itself: BA2T15D000A Main Clock Housing: BA2T15H000A Retaining Screws: BA2T15S000A Adhesive Pad Tape: BA2T15T000B Territory: Light Eucalyptus Colour Clock Assembly: SX15000A7L Bezel: SX15B000A Retaining Screw: V800426S437 No other components listed for Territory. |
#1150 | ||
#1151 | |||
Yep, thanks, have seen those. Mine is more a matter of busted housing. Did you notice there's also a guy selling those mechs with a blue backlit LED? |
#1152 | |||
https://www.ebay.com.au/itm/23479996...item36ab2b3188 |
#1153 | |||
#1154 | ||
Is the OEM AU T5 shifter bushing still available from ford?
Another thing regarding AU falcons are all the engine lower splash trays the same or are if I need a XR one does it need to be off an XR.
2001 AU2 220 XR8 - Build thread |
#1155 | |||
AU Manual Shifter.png All the lower splash trays/deflectors are the same on AU's, part number ER8B384A. GT |
#1156 | ||
Is it still possible to get steering wheels through Ford for the FG Falcon and the horn pad
I know the wheel part is BG3600D1 I’m going into Ford next week for a service so if I know it’s avalible I may ask them to order one seeing I have a few vouchers to use at the dealership |
#1157 | |||
The horn pad is actually part of the air bag and depending on what model you have can either be around $800 or $500. Still available though.. |
#1158 | ||
What about the steering wheel buttons in black BG9C888A
#1159 | |||
23 in attached pic is the bushing. Thanks m8
#1160 | ||
#1161 | |||
#1162 | ||||
https://srpauto.com.au/ford-parts/tr...h-ea-bf-xg-xh/ https://srpauto.com.au/t5-gear-lever...d-ea-bf-xg-xh/ On the pricey side, but might outlive car. EDIT - Just saw other brass options for the $25 to $35 mark. Google "T5 Gear Lever Bush for Ford EA-BF XG-XH". |
#1163 | ||||
Regular...with metamusal
![]() Join Date: Oct 2009
the clock housing has a very good double sided tape on the base so it sticks solidly to the windscreen, so that is why they end up busted. possibly need a thin serated blade to cut the tape?. and the clock part from it is actually the mighty AU clock. it is also the same clock part fitted to the Terri console/roof clock/sunglass holder. i found a cheap complete clock/housing & wiring loom ages ago, however the housing has a coupla broken bits [that i can hopefully repair or replace?]. weird looking when mounted behind the rear view mirror. and as i found when looking at it ...... the clock housing MUST be removed first from the windscreen before you can think about undoing the housing screws. Quote:
there's also T5 T5 altho they both only say "XF XG EA EB ED EF EL" but a slightly cheaper price. cheers Last edited by mad2; 29-12-2022 at 09:07 AM. Reason: add extra info |
#1164 | ||
Thin wire like fishing tracer is good for getting behind things to cut two sided tape or glue
#1165 | ||
#1166 | ||
GT you are a LEGEND.
Thanks so much again. The arm that has many different names on Ebay is in the center of 5A649B. These in pictures look the same for the Ba Falcon and the SX 2005 Ford Territory. Could you kindly check if they are the same please. Thanks Gazza. |
#1167 | |||
No problem, happy to assist. So the arm is same LH/RH and has a description of: ARM ASSY - REAR SUSPENSION, LOWER ARM - REAR, RH/LH For BA/BF the part number is BA5A649B. For SX Territory, the part number is SX5A649B. So based on catalogue data, they are different. Not that I have seen them side by side to compare, but there must be some sort of difference be it minor or major and they may in fact be interchangeable, but by part number they are different. Let me know if you need any help sourcing any of the parts. GT |
#1168 | ||
Hi would you know the motorcraft part number for the AU2 XR8 Cam Angle Sensor + Synchronizer?
#1169 | ||
#1170 | ||
yes thanks mate
