Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member. |
#1171 | ||
WT GT
![]() Join Date: Jan 2006
Hi GT, I'm going to buy a dash mat for the 2011 WT Fiesta off fleabay, but the prices are all over the place (very cheap to expensive). Was there a OEM offering and what did it cost please? Just looking for a reasonable product.
Many thanks https://www.ebay.com.au/sch/i.html?_...n%3AWT&_sop=15 |
#1172 | |||
There was never a genuine dash mat option for WT Fiesta.. GT |
#1173 | ||
#1174 | |||
#1175 | ||
Cheers, what part number to buy for new ones?
#1176 | ||
#1177 | ||
Thanks - if you can supply a pair of these nuts this week, please PM me the cost and I’ll transfer it.
#1178 | ||
When your nuts are on the line, count on GTLEGEND.
Thanks, as always, for speedy service - good advice - happy prices. |
10 users like this post: |
#1180 | ||
Hello GT
Not a big part but I am chasing a screw and the screw cover for the taillight in the boot lid spoiler on my 2014 FGX XR8. If you have them, I will grab a couple of each, so I have a spare. Thank you. |
#1181 | ||
#1182 | |||
From what I believe, these are only available as part of the whole light assembly, never sold as a separate part. Unless we can work out if the fastener is used somewhere else on the vehicle, we are unable to get separately. GT |
#1183 | ||
Ok Thanks very much GT for the quick reply.
The few other places I tried haven't rushed back to me and now I understand why. I will have to try and make do with a generic screw - but the cover might be a bit trickier. Thanks again. |
#1184 | ||
![]() Join Date: Mar 2007
Use a bit of clear nail polish on the thread when you refit the screw (as well as the old one still there) and should never come out of it's own accord again. But still easy enough to remove when needed. Cheap version of loctite. Taught to me by my old man who was a RAAF instrument fitter, so pretty sound recommendation.
Labels are for jars, not for people. Life is a journey, not a destination. ~~~~~~~~~~~~~~ Daily: 2013 FGII EcoLPi in Winter White Play: 2015 FG X XR8 in Emperor Show' N Shine thread Gone, but not forgotten: 2015 SZII petrol Titanium Territory in Emperor |
#1185 | ||
Thank you
#1186 | ||
GTLEGEND,
I have a plastic (chrome looking), boot lifter on the AU2 (Year 2000), the part that holds the rear number plate light fitting. Also has the "Ford Badge" in the middle. My apologies for not knowing the proper name of that item. I would like to get it replaced with the same chrome type, the studs or mounts that hold the item onto the bootlid has been broken long time ago. Can only do so much with superglue. Cheers. |
#1187 | |||
Either or they both no longer available, so need to keep any eye out on eBay or the alike. |
#1188 | |||
Thanks for that. On the VIN build date said June 2000. I guess mine would be the latter one. |
#1189 | ||
gday GT, can you please supply part number, availability and cost for the drivers side A/C blend door actuator for a 2011 fg my10. thanks in advance.
#1190 | |||
If I am thinking of the same part you are, it should be BA19E694A. If you can confirm thats what you are after, they are available, $400 plus postage. GT |
#1191 | ||
thanks for that info. a bit pricey for me so i will try to source a second hand one. cheers.
#1192 | ||
Question? Did Ford change wheel arch liners fronts from BA to BF just did a wreckers run and I swear left and right both off BAs I assumed but they screw up to the lower number different just curious if part numbers are same or different
#1193 | ||
Same part number for both front wheel arch trims on BA/BF.. should be no difference.
#1194 | ||
Peter Car
Hi GT.
Trying to get hold of some Territory rear brake pads. My local dealer told me they don't have them anymore. This can't be true right? Also I was trying to get hold of some upper control arm bushes for FG G6ET, but apparently only come in an expensive kit. I'm assuming by kit they mean the bushes only come with new control arms as well? And the bushes can't be purchased on their own? |
#1195 | |||
You need to find another dealer. Rear pads for a Territory are all the same from SX through to SZ2 and are still readily available. There are two choices of either genuine OE style or the Motorcraft pad option as well. As for the upper control arm bushes, correct not available as stand alone bushes, only as complete arm assembly which is arm/ball joint/bushes/brackets. |
#1196 | |||
Peter Car
How much can you do a set of those pads for? Next closest dealer is 45 mins away so not worth the drive. |
#1197 | |||
The Motorcraft ones $60 plus postage as above. |
#1198 | ||
Peter Car
#1200 | ||
Wow at that price difference, I thought Motorcraft was a ford part supplier, and as good quality?
Current 2009 FG GTP Sold 2003 boss 260 xr8 daily driver 1991 eb1 xr8 once a year driver, factory cassette player |
