Old 18-02-2023, 09:55 AM   #1231
GTLEGEND
Originally Posted by mchaggis View Post
Thanks for the quick response, I've taken a pic of the single lug left in the drivers side. I've tried different eBay and Jefferson Ford listings, but they all are subtly different.
Cheers.
Leave it with me for a bit will see what I can find. What part numbers have you seen or tried so far?
Old 18-02-2023, 10:01 AM   #1232
mchaggis
mchaggis's Avatar
Thanks again GT.
It was Bayford, and the ID was W715014SS3JA6. Although as I look at the listing it's FG, so was never going to work, but I hadn't seen anything so gave it a go. The others that I've tried are the lugs that fit the aftermarket 'Tickford' embroidered mats that you find around the place.
Cheers.
The Current Fleet:
2018 Kia Sportage GTLine
2014 FG-X G6E T
2012 FG-II GTP #288
2002 AU-III XR8
(1977 TE Cortina, 2001 AUII XR6, 2004 BAI XR8 Ute, 2005 BAII Typhoon, 2008 FG F6, 2015 FG-X XR6 Ute, 2006 SY Territory Turbo Ghia...it just used too much fuel)
mchaggis is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2023, 10:07 AM   #1233
GTLEGEND
Thanks again GT.
Cheers.
Definitely not that part, that a plastic clip made to secure mats on pretty much everything bar any Falcon including FG.
Give me a few days, I will see what I can dig up, they may be no longer available but hopefully we can at least dig up a part number. It may have also been part of the mat kit and not available separately. Be in touch..
Old 18-02-2023, 03:33 PM   #1234
XR Martin
XR Martin's Avatar
It may have been mentioned prior, but can you obtain the security codes for EA - AU radios?
2004 BA wagon RTV project.
Old 18-02-2023, 07:54 PM   #1235
GTLEGEND
Possibly, as long as the radio is from the original VIN, in other words need to know the VIN the radio was originally from. If there has been a swap over the years, it may come back incorrect. Worth a shot though..
Old 18-02-2023, 09:40 PM   #1236
Linz
*SILVER SERVICE PILOT*
Hey GT, was there a revised bonnet cable and fuse box for B series cars to fix the common breakages a few years ago?
Thought I recalled a stronger fuse box mounting point where the bonnet cable attached?
BUILD THREAD
Linz is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2023, 01:25 AM   #1237
GTLEGEND
Hi Linz,
I am pretty sure there was no updated cable, just the fuse box. It went from a BAF14A073A part number to a BA14A073A. If memory serves me right the change came about in 2010..
Old 21-02-2023, 01:49 PM   #1238
FPV 460
So B is $124
C is $310
F is $24
G is $90
All still currently available, postage on top of course which pending on weight around $20.
Hi GT. after some research im wondering if its possible to get C pulley only without the tensioner arm?
cheers
FPV 460 is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2023, 11:07 PM   #1239
GTLEGEND
cheers
Hey mate,
Officially no. I am not sure if the pulley is bolted or pressed on to the tensioner, would need to see one in person. It may not easily be removed, but if it is, then we would need to see if it matches the other pulleys.
Guessing Ford made it non removable for a reason if so.
Old 22-02-2023, 01:57 PM   #1240
FPV 460
Hey mate,
Ok thanks for that.
Can i then please just order B, F and G ?
Old 22-02-2023, 10:51 PM   #1241
GTLEGEND
Ok thanks for that.
Sure just PM me and we can go from there unless you still have the details and do as per previous times.
Old 23-02-2023, 09:24 AM   #1242
bondy99
GTLEGEND
Would you know if this screw holder is still available?
I may require a new one down the track when I start working on the rusted panel.
Thanks
bondy99 is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2023, 06:31 PM   #1243
GTLEGEND
Originally Posted by bondy99 View Post
GTLEGEND
Thanks
For which vehicle?
Old 23-02-2023, 06:53 PM   #1244
XR Martin
XR Martin's Avatar
For which vehicle?
Looks like AU-Bf, under the scuff panel.
Old 23-02-2023, 07:10 PM   #1245
GTLEGEND
If its AU-BF, then yes can still get but only a handful left.
Old 23-02-2023, 09:10 PM   #1246
bondy99
[QUOTE=GTLEGEND;6788501]For which vehicle?[/QUOTE
The vehicle is an AU2
Old 23-02-2023, 09:12 PM   #1247
bondy99
What would be the cost for those?
Thanks
Old 23-02-2023, 09:42 PM   #1248
GTLEGEND
Thanks
$2 each plus postage..
Old 24-02-2023, 01:22 PM   #1249
bondy99
I'll need 3, send me a pm with details.
Thanks
Old 26-02-2023, 03:14 PM   #1250
GTLEGEND
Thanks again GT.
Cheers.
Is this the clip(s) you are looking for?
Old 26-02-2023, 04:04 PM   #1251
mchaggis
mchaggis's Avatar
Attachment 106248
Attachment 106249
I'll give it a go. Thanks so much for following up. Will you PM bank details? How many are available? I may as well take 4 if I can.
Cheers.
The Current Fleet:
2014 FG-X G6E T
2012 FG-II GTP #288
2002 AU-III XR8
Old 26-02-2023, 04:26 PM   #1252
KRISL
KRISL's Avatar
Do these screw into somthing under the carpet or is that thread going to grip into the carpet?
Are these the fg1 model?
Attachment 106248
Attachment 106249
Current 2009 FG GTP
Sold
2003 boss 260 xr8 daily driver
1991 eb1 xr8 once a year driver, factory cassette player
KRISL is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2023, 04:47 PM   #1253
George V
Hi GT,
Rocker shims for AU 6 Cyl - are they available?
Regards,
George
George V is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2023, 06:43 PM   #1254
GTLEGEND
Originally Posted by George V View Post
Hi GT,
Regards,
George
Hi George,
1.9mm Rocker shims that between the lash adjuster and the arm of the rocker had part number ED6K514A, obsolete and no longer available.
They were also part of the whole rocker arm assembly, part number EL6564B but they are also long gone.
GT
Old 26-02-2023, 06:52 PM   #1255
GTLEGEND
Cheers.
I believe there are about a dozen left, will PM you with details.
Old 26-02-2023, 06:55 PM   #1256
GTLEGEND
Look at image in post 1228, it screws into speed nut HC5. Suits BA BF FG FG2..
Old 26-02-2023, 08:22 PM   #1257
KRISL
KRISL's Avatar
Thanks, any idea what the speed nut clip clips to? To sop it spinning
Current 2009 FG GTP
Sold
Old 26-02-2023, 08:57 PM   #1258
George V
Hi George,
GT
Thanks GT.
Regards, George
Old 26-02-2023, 10:13 PM   #1259
GTLEGEND
There is also a plate strip that runs along the floor across the front of the seat.
Old 27-02-2023, 06:34 AM   #1260
KRISL
KRISL's Avatar
Hi GT.
I'm after the plastic guard for behind the left rear wheel
on a fg gt
Local Ford say there is no option,
it is trimmed differently where it meets the bumper,
And holes are in the wrong place to trim a standard xr g6 one
Current 2009 FG GTP
Sold
