Old 09-03-2023, 01:05 PM   #1
Bones59
Default NU (au) bonnet swap
Hi all < New to the forum , i have recently bought a 2000 NU fairlane Ghia V8 , PO had cut holes in the bonnet , i want to replace it with a bonnet with the Bulge . Can this be done without too much work or better still , straight swap . Thanks Mark
Bones59 is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2023, 03:21 PM   #2
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Default Re: NU (au) bonnet swap
do you mean this ?
https://www.ssv.com.au/bulge-bonnet-...airmont-falcon
Old 19-03-2023, 11:10 PM   #3
Bones59
Hi . Yes thats what had in mind ? Would that be a direct bolt on or any mods needed .thanks mark
Old 20-03-2023, 10:19 AM   #4
Uncle_Ken
Uncle_Ken's Avatar
I would say probably no, HOWEVER I would call the guys on that website to confirm you can. (Edited for future questions.)
Old 20-03-2023, 11:28 AM   #5
Bones59
Smile Re: NU (au) bonnet swap
Uncle_ken , Thanks for your suggestions, i will contact them and see how i go . Mark
Old 25-03-2023, 11:09 AM   #6
Uncle_Ken
Uncle_Ken's Avatar
How did you get on?
Old 25-03-2023, 01:27 PM   #7
Bones59
Have emailed them , but no reply yet .
Old 02-04-2023, 01:08 AM   #8
PG2
#neuteredlyfe
PG2's Avatar
I think that what you are essentially asking is if the Falcon bonnet will fit a Fairlane? If so, then no the Falcon bonnet will not a Fairlane.
If you are asking if the bulge itself will bolt on easily then sorry, the answer to this is also no. I am sure that you could do it, but it would not be as easy as bolting it straight on.
Old 02-04-2023, 11:55 AM   #9
Bones59
Thanks for the message , will do more research
Old 02-04-2023, 12:13 PM   #10
GasoLane
Former BTIKD
GasoLane's Avatar
These pics may give you an idea of the difference.
screenshot utility
Old 02-04-2023, 12:39 PM   #11
Uncle_Ken
Uncle_Ken's Avatar
looks like a no fit to me, Thanks mate.
