#1381 | |||
#1382 | |||
SX SY Tailgate Inner Trim.jpg |
#1383 | ||
GT,
I managed to obtain a working electric car aerial for the AU2. Problem is, the plug connector is missing. Would those plug connectors still obtainable? If not, do you have a diagram / pic as to what they look like? Thanks bondy. |
#1384 | |||
![]() Join Date: Oct 2006
![]() If so, you should be able to crimp a two pin molex like this on https://www.altronics.com.au/p/h2309...ine-connector/ to the wire you have and on the aerial. RS Components likely will have the exact fitting part if that's your preference see https://au.rs-online.com/web/c/conne...rchTerm=molex. etc. Possibily this https://au.rs-online.com/web/p/wire-...-plugs/7976569 but if not, and you search with the string "Molex 2-way" on the RS Components site you'll find other options in the thousands they list.. If the aerial coax this: https://www.altronics.com.au/p/p0184...-antenna-plug/ or https://www.jaycar.com.au/solderless...0f94423916de00 will do it.
regards Blue Last edited by aussiblue; 02-05-2023 at 03:43 AM. |
#1385 | ||
aussieblue,
Yes, it's the power cable plug where the green and red wires go into. Photo does help. Cheers. |
#1386 | |||
'19 Wildtrak PX3 3.2 6spd, White '09 SY1 Terri TS AWD - still going strong, now wifey's |
#1387 | |||
GT |
#1388 | ||
Are you able to take a closer picture or write down the part numbers that are on the back of the trim you are holding please.
#1389 | ||
I would need to see the connector face to see if one is available, cant remember what one looks like and the image provided is not clear enough.
#1390 | ||
George
![]() Join Date: Jun 2015
Hi GT, could you please try and source a tailgate pull down strap for me, 434A14, like the one in this pic,
![]() I would like to fit one to my boot lid. Thanks, George.
BFWSM https://www.fordforums.com.au/vbport...articleid=1708 http://fordforums.com.au/wsmpub/ba/501-05.html ![]() R/U 2019 ![]() ![]() ![]() PWR Air/Oil Cooler, K&N, Egas elbow, V8 upper F6 lower CAI. 1997 Fairmont EL Ghia Tickford 4L Auto ![]() 1985 Falcon XF GL 4.1L Auto. 1979 Fairmont XD Ghia 4.1L Auto. 1971 Cortina GL Estate Manual. |
#1391 | |||
I do understand. I too have not seen what it looks like, the image I seen earlier was wrapped around with some type of foam material. |
#1392 | |||
Don’t spend much of your time on this one GT, if this number doesn’t lead to anything, i can just stick the trim back with some good quality double sided tape 👍
#1393 | |||
regards Blue |
#1394 | |||
Not a problem, $25 plus postage, choice of Warm Charcoal or Medium Eucalyptus colours. Let me know which one you want. PM if you want to get. GT |
#1395 | ||
Thanks GT, here couple of closer piccies:
#1396 | ||
Hi GTL. any chance of NOS FG FALCON RADIATOR HEADER TANK OVER FLOW BOTTLE availability and price for 2011 boss335?
cheers |
#1397 | ||
#1398 | |||
If you need the cap as well they are obsolete so would need to go searching. |
#1399 | ||
Ah ok, that's just the matrix showing the DOM i think :
#1400 | ||
#1401 | ||
Hi GT
I am after part number, price, and availability for the front hub/bearing unit mounting bolts for a FG Falcon i6 4L 2008, VIN: 6FPAAAJGCM8C75922, Rego OZB01 please. Thanks Jason |
#1402 | |||
Part number of the hub to knuckle bolts is W705821S439, $19.50 each and still available. I am sure there are 3 per side required. $10 for tracked postage if need be. GT |
#1403 | |||
Correct, this trim is not on the tailgate itself, but on the vehicle body where Ive circled in red in this piccie. Thanks again ;)
#1404 | |||
SX Territory Roof Trims.jpg |
#1405 | |||
thanks again. |
#1406 | ||
*SILVER SERVICE PILOT*
![]() ![]() Join Date: Jul 2006
Hi GT, are the BA/BF front guard side repeater lights still available please?
![]() There's heaps of non genuine ones out there, but thought I'd check if genuine are still available.
BUILD THREAD
https://www.fordforums.com.au/showth...71#post6891271 2006 Lightning Strike BF Fairlane Ghia...HIS 2024 Titan Grey Hyundai Tucson Highlander...HERS |
#1407 | ||
#1408 | ||
2 users like this post: |
#1409 | ||
The arrow points to where a steel water transfer pipe sockets into a cast alloy housing which also supports the thermostat above.
(Picture from BBT Jap Parts of Lambton NSW, via Fleabay.) Is the o-ring seal for that steel pipe, anything unusual like a square profile? I have a modest leak on the Territory’s one, and maybe also the white ute… If it’s a specific Ford part, are they still available? (I’m using 2:1 green coolant which has a knack of finding small leaks.) |
#1410 | ||
Peter Car
It's not a square profile. Just your regular o-ring.
