Old 10-07-2023, 07:43 PM   #1
Default Decent Clamps for Battery Charger
I’m surely not the only person here who’s “over” rubbish clips/clamps on battery chargers and other similarly connected devices. Always low quality plating over steel, always the steel breaks through and corrodes.
Are there any durable clamps to suit soldering/crimped termination, with insulated grips? Cast or stamped brass is probably ideal.
Old 10-07-2023, 08:42 PM   #2
Default Re: Decent Clamps for Battery Charger
These https://www.amazon.com.au/700-Amp-Al...%2C323&sr=8-14 ?
Old 10-07-2023, 08:51 PM   #3
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Originally Posted by aussiblue View Post
I like how they have the battery lugs bolted to them and are removable, rather than the crimp style termination.
Old 10-07-2023, 10:11 PM   #4
Itsme
Itsme's Avatar
I have a set of these for my charger which can be interchanged with other devices.
https://www.jaycar.com.au/high-curre...ttery%20clamps
You can also get these at www.alltronics.com.au
Old 10-07-2023, 11:27 PM   #5
What are the actual clamps like? Have been contemplating going Anderson with eye terminals for the regularly charged cars, this might be a step in the same (compatible) direction.
I’m a bit suspect on the Amazon ones as they look like brass plated steel, not “copper”.
Old 11-07-2023, 06:54 AM   #6
roKWiz
Cabover nut
roKWiz's Avatar
Maybe not suit your application but I regularly charge batteries using a portable large solar array wired with 30 amp Narva ring terminals using wing nuts on the battery terminal ends for quick disconnect.
Best way I've found to make a solid contact.
Old 11-07-2023, 06:57 AM   #7
cs123
cs123's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Can't think of anyone more deserving. Russ Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For all the technical support behind the scenes. Tech Writer: Recognition for the technical writers of AFF - Issue reason: Technical submission
I've always been fond of this style
https://www.repco.com.au/globes-batt...hoC3f4QAvD_BwE
Or this style and fit your own connector to the charger
https://www.ebay.com.au/itm/17217593...BoCQvkQAvD_BwE
I love Holdens....
cs123 is online now   Reply With Quote Multi-Quote with this Post
Old 11-07-2023, 07:56 AM   #8
mad2
Regular...with metamusal
similar to what i have changed the car terminals too.
Old 11-07-2023, 09:08 AM   #9
tbro4123
Looks like its time for a trip to CoolDrive/ JAS/ Ashdowns/ AEA.
I found having accounts at all of the above if one didn't have something the next one would,
saying that CoolDrive and AEA were probably the best for heavier hardware.
Don't expect to find quality sparkies or trades quality at Repco/supacr** etc,
they just either have never done it or just aren't in that market anymore.
Terry
tbro4123 is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2023, 09:49 AM   #10
Itsme
Itsme's Avatar
They are decent clamps in my opinion, they have a good strong clamp feel and not too big or small if you get my drift, best I've seen from what you get from any auto shops.
Old 11-07-2023, 11:06 AM   #11
vinverify01
alex
Through internet search i have found, the NOCO GC017 Battery Clamp Connector is a popular choice for its sturdy construction and secure grip. It features durable alligator clamps with copper-plated jaws that provide excellent conductivity. The clamps are also equipped with built-in safeguards to prevent overcharging and reverse polarity.
vinverify01 is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2023, 12:34 PM   #12
Yes looks like solid brass to me per per https://beryllium-copper.com/2020/09...ing-materials/ and the brass pipe fittings and cast copper fittings you get in Bunnings etc e.g. https://www.bunnings.com.au/brasshar...union_p0252404 and https://www.mscdirect.com/product/details/70494489
Why not ask the listed Australian buyer on Amazon to confirm they are solid copper brass?
Old 11-07-2023, 02:42 PM   #13
Bolly47
Talking Re: Decent Clamps for Battery Charger
I’m a bit suspect on the Amazon ones as they look like brass plated steel, not “copper”.[/QUOTE]
Got couple of Brass clamps use for welding (Amazon) however Brass clamps is 100% brass. no steel plate
Bolly47 is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2023, 02:59 PM   #14
Electrolyte Burns
“copper”.
All copper would be way too soft to be adequate.
Electrolyte Burns is offline   Reply With Quote Multi-Quote with this Post
