05-08-2023, 10:35 AM | #1 | |||
Rob
My daughter has an SA Focus. We have ZH Escape. They aren't much higher off the ground but it makes a lot of difference getting in and out. My folks traded their falcon on a Tucson. They'll never go back to a non suv. Being slightly higher off the ground is what the market wanted.
UA2 TREND 4WD BI TURBO |
05-08-2023, 11:08 AM | #2 | ||||
You're comparing apples and oranges between the NA Fiesta and the boosted Puma, one uses ye olde Ford Sigma engine with VVTI and the other is a modern turbo 1L 3 cylinder engine - compare it with a WZ Fiesta Sport which has the same engine as the Puma. We've got both a WZ ST Fiesta and a povvo spec 1.6L WS CL Fiesta - the WZ ST Fiesta uses less fuel than the naturally aspirated variant while making twice the power and torque, both 1.6L 4 cylinder engines but one dates back to the 1990s. I took said WZ Fiesta ST on a 4000km drive across VIC/NSW/QLD and ACT, and I've used it for Adelaide and return six times, I wouldn't say its 'uncomfortable' or 'difficult' to get in and out of but I suspect my tolerance is higher. We've got the least amount of choice ever in the new car market we've ever seen, you want something thats not an SUV or a Thailand Special then good luck. Two options under $60K for someone who wants something thats manual and boosted: Hyundai i30N Subaru WRX I think the problem is I actually enjoy driving, the people who buy SUVs use them to get from A-B and thats why a white goods manufacturer like Toyota dominates the market. Trying to change my opinion about SUVs and Thailand Specials, you'd have more luck convincing a brick wall Last edited by Franco Cozzo; 05-08-2023 at 11:14 AM. |
05-08-2023, 11:22 AM | #3 | ||
Rob
Incorrect. I enjoy driving also however I'll keep my territory over falcon any day.
How tall are you? How old are you? I suspect that might tell a story.
05-08-2023, 11:29 AM | #4 | |||
I find with the lower back, its more about the seat itself and its support rather than the height of the seat - something with a flat seat is a problem, but the Recaros in the Fiesta ST - mint. If the seat is flat then its 20 minutes before I got dramas, if its good, then I can drive non stop. All the Euro Ford hatches, the seats are great from the povvo spec right up to the ST models. |
05-08-2023, 11:37 AM | #5 | |||
I moved to suv at age 67. |
05-08-2023, 11:41 AM | #6 | ||
05-08-2023, 11:41 AM | #7 | ||
Cabover nut
Good luck with the truck ownership then.
05-08-2023, 01:03 PM | #8 | |||
Rob
I'm only 46 and had to have surgery last year (l5s1). It's a long road after that. You only get 1 back. That's why higher cars are more popular with those slightly more senior in years.
UA2 TREND 4WD BI TURBO Last edited by prydey; 05-08-2023 at 01:15 PM. |
06-08-2023, 11:11 AM | #9 | |||
...I'm 56 or 57 or 58 depending on the am caffeine intake...and that point where your upper weight is fully on your bent knee joints when dropping down into the seat is a bitch... |
06-08-2023, 12:51 PM | #10 | ||
You just cannot beat an SUV over a regular sedan in regards to ingress & egress,as you get older you very much appreciate not having to bend down.They are so much more comfortable.
2015 WZ Ford Fiesta ‘S’ Ecoboost .2022 Honda HRV e:HEV in Premium crystal red. |
05-08-2023, 11:36 AM | #11 | |||
You are damning yourself. You should drive (Puma)one. And only then can you compare. Umm I have a confession to make. MG ZS $23990. I got a lift in one yesterday. Quite a tidy interior. Good looking seats but flat and probably unsupportive. I couldnt pick the gear changes. As basic a-b transport burbs area for a non driver driver I can see why people buy them. I would not buy one as I like a car to be a driver drivers car even if its only in some areas. |
