11-05-2024, 12:41 PM | #1 | ||
I have been on Facebook to find out what I need but now I'm even more lost
I want to scan as I I have a misfire problem changed the mechanical stuff to no avail So can someone tell me what dongle I can buy from a shop and the link to the specific forscan download for a android phone I have no idea about I.T. stuff so assume you you are speaking to a 2 y/o and that's being generous |
11-05-2024, 01:41 PM | #2 | ||||
Regular...with metamusal
checkout the Link for the version you want. click on what one you want & it will download [at least on my desktop it does] and go from there. you will need a compatible bluetooth dongle [which i have NO idea about]. with the AU's you may not see the whole car system so don't stress over that bit. on the link checkout what links it has for more/differant info. you can also join and ask questions or join Forscan on facebook & ask there. personally i use a windows laptop version as it is easier for me to use & workout. |
11-05-2024, 02:25 PM | #3 | ||
No laptop and there are hundreds of downloads on forscan which confuses me
Ta anyhow |
11-05-2024, 04:02 PM | #4 | ||
Next upgraded Mk1 Leopard
From my build section.
11-05-2024, 07:00 PM | #7 | ||
11-05-2024, 07:14 PM | #8 | |||
there's NOT hundreds .... seeing as your doing it by phone.. there's just whats shown in pic. use the last one on the shown list to make sure & if it's all good on your phone, then either buy thru the google store [2nd] or straight from Forscan [1st]. you can buy what ever bluetooth your happy with or buy what's offered thru FORScan's links [which was on the page i linked previously]. |
11-05-2024, 07:28 PM | #9 | ||
You can also do the switch mod yourself:
https://www.facebook.com/lindaobd/po...9262963656034/ and https://blog.uobdii.com/how-to-modif...ms-can-switch/ etc
regards Blue |
