#1951 | |||
Regular...with metamusal
![]() Join Date: Oct 2009
with the plug all you need is the one with the small magnet fitted. i have the factory wagooon wiring/sensors one x3. i tried setting up the factory unit quite a few times. even had it working on 'Ol yella [x-taxi wagooon]. but i could never get it going/working properly on the BA M7 wagooon?. i ended up fitting aftermarket sensors with my own wiring [except for the sensor part] and the trailer part [for which i will eventually throw away the factory 12 pin & replace with a flat 7 pin, with a magnet of course!]. all works great now! .... well did till i blew/contaminated the gearbox ![]() cheers Ps. all you need then is the wiring which you can easily get a hold of. and the 12 pin plug which is easy to find here or here. i will be trialling this one or this one as i don't remember what 12 pin i used? [wired up my own edition with a change to the reverse lights as well]. |
#1952 | ||
Hi GTLEGEND
Was referred to you by other members as you may be able to help 2013 Ford FG EcoLpi MKII LPG We want to order a new oxygen sensor. i have seen some on ebay and other sites but the one they are selling has 4 wires. The one we have is 2 wires. My question is do we need to get a 2 wire sensor or can we use the 4 wire. Does that also mean that the FG has 2 types of sensors a 4 wire and a 2 wire one? Strange Any help would be appreciated |
#1953 | |||
Hope that helps, GT |
#1954 | ||
I am currently looking at a BA MkII Fairlane and I am wondering what the chances would be in obtaining a Bonnet Protector, Headlight Protectors and the plastic Mud Spats for this Model. A few cars I am looking at do not have them on.
#1955 | ||
Nothing genuine from Ford, keep an eye out on eBay, Market Place etc etc
#1956 | ||
hi
Many thanks Looking for part no. for Ford Ranger pj/pk and Mazda UN 4x4 model location /part front lower inner wishbone bushing [mounted in front position ] rear wishbone bushing mounted in chassis bolts nuts washers etc both wishbones lower inner bushing fasteners ,,position front and rear both LHS and RHS My vehicle is corroded in that area |
#1957 | |||
#1958 | ||
hi GT
Mazda BT50 UN single/regular cab 3.0lt diesel 4x4 5spd man del date jun 011 build date 1/11 Vin MM00UNY0E400891415 I read the 0 as Zero from recent Maz dealer road worthy receipt |
#1959 | |||
PK Ranger 4x4 Front Suspension.png |
#1960 | ||
Suspension bushings
lower inner wishbone 2 different bushings / 2 different mountings 2x parts diagrams required A/ the one u have shown [bushing mounts in wishbone] B/****chassis picture required [bushing mounts in chassis ] 34-463 front bush 9YA00-1208 bolt plus the washer and nut 9YA14-W601 plus washer and nut |
#1961 | |||
PK Ranger 4X4 Front Suspension 2.png 34-463 $25 each plus postage. 9YA00-1208 Need to chase, not coming up for some reason. 9YA14-W601 $20 each plus postage. GT |
#1962 | ||
hi
When looking to find I found a picture in the chassis parts section showing the suspension bushing . This section showed no other suspension components . I will try to get the sections title name . Chassis,piping and fuel tank >>>> then >>>sub menu chassis and undercover From an official Mazda o/seas site Oh yea exactly where the only suspension bush should be ,,really !!! An idea might be to keep it in the front suspension area ,, geeeezus LOL Last edited by swamp; 02-06-2024 at 08:37 PM. |
#1963 | |||
PK Ranger 4x4 Chassis.png |
#1964 | ||
hi
Correct 34-460A Remember when there were 1995 Ford Spectron vans . The rear upper wishbone bush is the same ,, all be it in the 4wd version . Last edited by swamp; 03-06-2024 at 05:11 AM. |
#1965 | ||
#1966 | ||
hi
Thankyou PS Do Ford only do one version of Torsion rod ?? price and availability please Maz numbers Lh,,, UR7634T21 RH ,,,UR7634T11 |
#1967 | ||
#1968 | ||
hi
The ""other"" unit is nil stock Australia ex Japan my enquires tell me . Is this true ? Waiting 2mth approx is ok Once the prices are known I will make decision from there Happy with the price of the in stock unit Thanks PS My research tells me there is no optional factory HD set . Strong believer in factory style torsion bars in good condition . There is a reason why after market suspension requires shock mount re enforcement ,, way to hard suspension setup . |
#1969 | ||
Hi Gt
How is the price and availability looking for the LH , UR7634T21 any info yet ? Cheers Paul |
#1970 | ||
#1971 | ||
hi
LHS $650 RHS $130 Anyway of enquiring about the price .?? Sounds like someone drunk at there keyboard when setting the price .!! Not going to say there the same part physically [I did] but wow . |
#1972 | ||
Yeh I am trying another contact whom I am waiting a call back from, will let you know asap..
#1973 | ||
So confirmed the price of the LHS and that is correct, reason being that it is ex Japan and may actually need to be remade.
#1974 | ||
hi
Do both brands Mazda and Ford get there parts from the same source ?? Who did u enquire thru ?? |
#1975 | ||
#1976 | ||
hi
Thanks for trying on the torsion rods Rear diff drain plug UH7126051 washer to suit UH7126187 sway bar link bolt 9YA001002 washers 018734776 rubbers UH7134152 nuts 999211000 and 999221000 * enough qty to do both sides bumpstop rebound UH7126187 2 x req front diff mounting bushes UR6139540 3x req UR6139550 4x req UR6839560A 1x req rear leaf springs UR7628L10B |
#1977 | ||
Barra Turbo > V8
Chasing an FGI 6 cyl Power steering reservoir cap/dipstick, seems the seal on mine has failed. Have searched but come up with nothing.
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels - Tuned by LS Tuning and Performance |
#1978 | ||
Thanks for trying on the torsion rods Managed to find one a bit cheaperat $550.
Rear diff drain plug UH7126051 Obsolete but may be ableto source one. Need to confirm. washer to suit UH7126187 Available $3.50 each. sway bar link bolt 9YA001002 Only 3 left then obsolete $12 each. washers 018734776 Invalid number. I have washer UH7234157 at $7 each and 9 left then obsolete. The other is a retainer 022328776 available $34 each. rubbers UH7134152 Available $3.50 each. nuts 999211000 15 left then obsolete $9.50 each and 999221000 4 left then obsolete $6.50 each but they need to be sourced interstate so will need freight to get in approx $10. * enough qty to do both sides bumpstop rebound UH7126187 2 x req I think you have wrong number here, this is diff plug gasket. I think you mean UH7434110 $32 each. front diff mounting bushes UR6139540 3x req $12.50 each UR6139550 4x req $12.50 each UR6839560A 1x req $28 rear leaf springs UR7628L10B[/QUOTE] Obsolete.. |
#1979 | ||
Hi Legend.
another quick question for you. is there any differance between the replacement fuel pumps re sedan/ute/wagon?. just the pump. and yes most likely obsolete too. Thank you. ![]() |
#1980 | ||
