Yesterday, 03:01 PM | #1 | ||
Got a little water in px3 on weekend on pass side , electronics started playing up after that steering , hill assist , cruise control , ESC , pulled seat our and found a modual on floor , xmckeaned and dried it , my question can this be the cause and what it called if I need to source another
Yesterday, 09:05 PM | #2 | ||
hi
Water ingress can fry electronics today and in the future . The future problems can be caused by moisture or developed corrosion over time . If your unlucky modules that are wired to the wet unit may fail in the future also . The wiring because companies use the smallest possible size can fail as moisture wicks itself up the cable from connector and corrodes wires internally . The signal or power flowing thru can be intermittent . Obviously the above issues can be difficult to diagnose . In a simpler car all the dash and engine loom is removed dried and lubed . All ECU are removed and dried . About 7 --10 days work . No guarantee . |
Yesterday, 09:54 PM | #3 | |||
Experienced Member
As for your problems, maybe so or maybe not. |
Today, 01:20 PM | #4 | ||
how and where? Ranger is rated to 800mm deep wading so all the critical electrical joints should be above that.
Today, 02:14 PM | #5 | ||
800mm wading, not immersion...
Today, 04:01 PM | #6 | ||
well, it's 800mm at <7kmh, so pretty much immersion
