Old 15-12-2024, 06:39 PM   #1
Dave666
Default What's The Best Battery for My 2019 Focus SA Active - Auto?
While the battery in my 2019 Focus SA Active is still going strong, it almost 6 years old. I assume it could die any time after 6 years of age?
Does anyone know the best replacement battery for this car?
Dave
Dave666 is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2024, 07:42 PM   #2
Default Re: What's The Best Battery for My 2019 Focus SA Active - Auto?
Can you have it load tested at a Battery World? That’s usually a free service and should give you an idea of where you’re pointed.
Sometimes the OEM batteries from Jefferson Ford are actually best value for replacement.
Old 15-12-2024, 08:09 PM   #3
Dave666
I usually wait for my battery to die, then use the second car to do a dash to supercheap or similar outlet.
I was thinking a brand like Century or Super Charge, but open to a recommendation.
Old 15-12-2024, 08:57 PM   #4
Citing a favourite brand can be a risk, someone else lobs in with “I had one of them and it caused my car to <insert random event of choice>”…
My two most inconvenient experiences were with SSB batteries, the negative posts were hollow/porous and let acid vapour destroy the negative terminal clamp. However I still use the brand. I also have Century, AC Delco and Club Assist batteries in service. A good Lion was stolen out of one car, they are a Melbourne based brand but again, Korean quality.
Old 15-12-2024, 09:33 PM   #5
Dave666
After a bit of research on FF it appears that this car is going to let me know when the battery is on its way out (clever little car - recent purchase for us - still learning). So I guess I will worry about it then.
PS - You know your having a bad day when someone knocks off your car battery!
Old 15-12-2024, 10:12 PM   #6
EBSXR6
EBSXR6's Avatar
Dave
Bond Batteries if you can easily source.
EBSXR6 is online now   Reply With Quote Multi-Quote with this Post
Old 04-01-2025, 04:49 PM   #7
stefcio007
While the battery in my 2019 Focus SA Active is still going strong, it almost 6 years old. I assume it could die any time after 6 years of age?Does anyone know the best replacement battery for this car?CheersDave
Mine has date stamp of 5019 which means week 50 of 2019, still going strong, start-stop function works great.
I have a jump-starter stored in the spare wheel well just in case and will probably think about replacing the battery after I need to use that (I've actually used it 3 times to help other stranded people so I know it works).
2020.25 Focus SA ST-Line Wagon + DAP
2011 Focus LW Trend (Diesel) [sold]
2006 Territory SY Ghia (AWD)
stefcio007 is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2025, 05:10 PM   #8
marg99
usually the stop start function turns itself off when the battery is on the way out
