27-01-2025, 12:05 AM | #3451 | ||
Thanks DFB, that’s given me some homework to do. Much appreciated and thanks for the prompt response. Cheers
Currently no V8 in the garage! |
29-01-2025, 05:34 PM | #3452 | ||
Armour Detail Supply Ghost
I've met very few tyre dressings that I didn't like, and of those, I'd say most of them were from my early days when I didn't know what I was doing. Armour Detail Supply Ghost? Well, it's another knockout ADS product! https://autobuff.com.au/products/arm...t&_ss=e&_v=1.0 https://detailingshed.com.au/product...f09ed2e9&_ss=r Backstory - In my earlier days, I'd be using heavy solvent dressings such as Autoglym High Performance Tyre Gel, Meguiar's Endurance and Gyeon Q2 Tire, which were nasty products that created more problems than they solved. At the time, I thought a dressing that would last a long time was a desirable attribute. For the most part, solvent based dressings provide a longer lasting effect but are messier to apply and harder to remove...............important because they never truly dry and therefore hold onto dirt, dust and road grime. And if you happen to apply just a little too much, then it will be slung across your paint work and wheel arch liners. So, while I liked the look, I didn't like the many associated drawbacks. Autoglym HPTG - Meguiars Endurance - Gyeon Q2 Tire - At this point I should point out the three different types of tyre products - Tyre Dressing - A short-lived liquid or gel-like product that is applied frequently. I favour these products as they offer more flexibility, are easier to apply and easier to remove. Think NV Onyx, Carpro Perl, Meguiar's Hyper Dressing. Tyre Sealant - In most cases, these are solvent based gels that provide longer durability. By creating a barrier to moisture, tyre sealants typically last for weeks, not days. Think Gyeon Q2 Tire and Carpro Darkside. Tyre Coating - A ceramic coating designed specifically for rubber surfaces. Longevity is said to be months, not weeks. These require extremely thorough cleaning and prep prior to application. And even then, longevity is known to be variable. I have also seen where a tyre coating turned sidewalls permanently brown. Carpro Black-Out is probably the most notable product in this category. What is Ghost? And so, we arrive at Armour Detail Supply Ghost, which is labelled as a tyre sealant. Compared to the water-based ADS Tire+, which is a favourite of mine, Ghost can last up to 3-months. Compared to the solvent-based tyre sealants listed above, Ghost is actually a water-based "nano-sealant engineered for exceptional long-term durability." What sets Ghost apart though is how the formulation dries to the touch, meaning it won't accumulate dirt and grime. It's sealant properties create a hydrophobic barrier, and just like a sealant on paint, Ghost allows for easier cleaning. It can also help prevent oxidation and tyre browning, which naturally happens when rubber is exposed to sunlight. Application - When it comes to tyre sealants, preparation is key in achieving the claimed longevity. 1. Start by scrubbing the sidewalls with a strong tyre cleaner, think Shine Supply Wise Guy, P&S Undressed or Carpro ReTyre. If necessary, repeat the scrub process but don't go beyond 2 - 3 rounds, the next step will take care of anything left. 2. Once dried off, grab an old towel and either Stoner Tarminator or Mineral Spirits. Spray the product into the towel and rub the sidewall until it looks complete matte in appearance. These two chemicals are brilliant for stripping away anything lingering on the sidewall. (Note - This step is optional, but is worth the effort from time to time to reset the surface) 3. Prior to application, ensure the tyre is completely dry. Prime a foam applicator with 3 - 4 sprays of Ghost, then work the product into the sidewall. Subsequent tyres will need about 2 sprays. The neat thing about Ghost is the blue tracer which clearly indicates where you've been, in effect ensuring even and thorough coverage. This blue tracer will disappear in short order and leave behind a lovely satin sheen. 4. With one coat (as pictured below), Ghost will deliver a satin look. If you prefer a glossier appearance, apply additional layers with 10-minutes between coats. 5. Allow the product to cure for an hour before getting wet. Unlike other tyre sealants that seem to remain a little tacky, Ghost is completely dry after it has cured. The Follow Up - Pleased with the look, I was keen to see how this new tyre sealant performed during the wash process. Twelve days later at the next wash, Ghost was beading water impressively. The tyres on this occasion had a layer of dust on the very outer rim of the sidewall, most of which was removed by a simple rinse. Instead of hitting the rubber with a tyre cleaner, I decided to just give them a scrub with a car wash shampoo I used to clean the wheels. Afterwards, this is what they looked like..................... In this case, the tyres looked perfectly acceptable, but I actually decided to follow with a very light swipe over with ADS Tire+, because why not? Final Thoughts - As mentioned, for me the longevity aspect of Ghost is not my main priority. What I like most is how it looks, a classy satin sheen that was totally effortless to achieve. Compared to something like Capro Darkside, Ghost is extremely easy to distribute and requires faaaar less effort to achieve even coverage and a consistent finish. Anyone who has used Darkside will know what I mean there. So, if you prefer a tyre dressing that won’t need to be applied after each wash but also WON'T have the typical drawbacks of a solvent product, I now have something I can hand-on-heart recommend. And for the record, I was NOT paid to write this review.
The Fleet - 2016 PX MK II Ranger Cool White 2008 FG XR6 Sensation Blue 2014 FG X XR8 Emperor Red 2024 Mustang GT Race Red The Departed - 2002 T3 TS50 Blueprint 2017 Mustang GT Race Red |
Yesterday, 01:02 AM | #3453 | ||
T3/Sprint8
DFB, having Tire+ should I bother ?
Actually silly question - I’ll get one next buy as the next go to after Tire+ runs dry What is the difference by the way - longevity I suppose ? Sent from my iPhone using Tapatalk
Yesterday, 02:09 PM | #3454 | |||
I don't know the chemical difference, but Ghost is said to last for a couple of months (take that with a grain of salt, although ADS seem to be more on the ball with claims like that), Tire+ will give you wash off pretty easily.
Yesterday, 04:47 PM | #3455 | ||
T3/Sprint8
yes well doing the final touch is always satisfying I hear you......
OK points taken. I did my tyres last Saturday, here in Syd we have had couple days of rain. I didn't do heaps of k's but office and back Tues/Wed in the wet, checked the tyres atm they still look pretty good, tire+ coating is evident very much so pleased about this. Took a pic but tapatalk doesn't allow loading anymore.
