Old 12-10-2024, 08:23 PM   #61
Default Re: Castrol has discontinued TQ95
Dead certain, it will promptly flip onto its roof and catch fire. Also, cute kittens will die horrible deaths. That’s what happens when you use the wrong ATF.
Old 12-10-2024, 08:56 PM   #62
Only in Springfield, Ohio. But is it "Citroenbender" or "Citrorenvasillator" give here https://fordforums.com.au/showthread...13#post6921113 you said
No, you don’t put LV ATF in BTRs.
aussiblue is online now   Reply With Quote Multi-Quote with this Post
Old 12-10-2024, 09:24 PM   #63
1970XW351
Angry Dub Driver
1970XW351's Avatar
Loaded up with four bottles from my local supercheap today. That should see me clear until I can sort out a manual conversion for the "old" 'mont... And then I can probably sell any remaining bottles for ONE MILLION DOLLARS!
Not happy about the price to play this silly game though, last time I bought a bottle I swear it was sub $50 and not even on special.
Cheers, Tony
1970XW351 is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2024, 10:32 PM   #64
LV ATF is a different range of fluids; Penrite, Nulon, Hitec all offer such - it’s used in place of stuff like Lifeguard 6. Irrespective of the price, I wouldn’t put such in a BTR box from EA through FG.
Old 13-10-2024, 08:26 AM   #65
Falcon SXR8
Falcon SXR8's Avatar
Seen a question regarding what oil to use in the btr now that tq is gone on a rvo transmission facebook post. They said to use dexron 3 with a lube guard product called shudder guard, depending on what clutches are used in the transmission they can make a squark noise shifting into 3rd without it.
Had
EB XR8
AU XR8 220 (awsome car )
AU Fairmont
BA MK2 XR6 Turbo
Now
XDUB
Falcon SXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2024, 10:21 AM   #66
jpd80
jpd80's Avatar
Interesting thread
So the difference over Dex 3 is that additives to protect planet carriers from wear,
this would seem to be what happened when GM went from DEX 3 to DEX 6 and
the equivalent Mercon LV which is rated for Ford 6R80 (ZF box) as well as 10R80.
It is possible that BTR went to a new trans fluid standard years ahead of what was
normally in use but now is probably covered by the later GM/Ford universal oil?
jpd80 is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2024, 12:39 PM   #67
Or perhaps it's simply as one of the companies I contacted seeking TQ95 observed: "Castrol Australia appears to have progressively lost all interest in their own products and servicing the Australian market and their own products and Australian customers since being merged with BP in 2000". The temporary withdrawal of Castrol Edge and then its repackaged reappearance might perhaps also be a symptom of this. I also wonder they are now simply repackaging BP products or one of its other associated lubrication oil producing subsidiaries as Castrol products.
Old 08-01-2025, 09:00 AM   #68
ESeriesKev
I contacted Castrol about this and got the following response:
The driveline technology team at Castrol have determined that Castrol Transmax ATF DexronVI Mercon LV Multivehicle meets all the performance requirements and can safely be used as an alternative to TQ-95. When TQ-95 was first developed, this would not have been the case, there were no other ATFs available.
Transmax ATF DexronVI Mercon LV Multivehicle has been recommended for some time now. I have not received any negative feedback after using this ATF.
ESeriesKev is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2025, 10:02 PM   #69
Unicorn
Originally Posted by aussiblue View Post
Opps that should have been:
Ford was the first 4 Speed BTR equipped Ford car registered and licensed in Australia my prototype August 1989 made NB Fairlane. Doubtless one expects there were earlier unregistered test mules and the like. In any event TQ95 was developed by Ford and Castrol in conjunction with the transmission. There may also have been an earlier version of the ATF as "TQ85" appears in some handbooks and it is unclear if this was just a misprint or evidence of an earlier version of this fluid and truth is probably now lost in history.
There is definitely references to TQ 85 being available and that TQ 95 is a direct replacement.
Unfortunately There seems to be no TQ 95 compatible replacement.
Autobarn had 70 4l bottles 3 months ago that is down to 17 now.
Unicorn is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2025, 10:10 PM   #70
Unicorn
Originally Posted by Franco Cozzo View Post
Curious as to the effects if you fill it with Dexron VI,
I think if you have a rebuilt box then you should see no issues.
The problems seem to occur as the seals age as the alternatives to TQ 95 are too thin.
I tried non TQ 95 in one of my warn boxes and within weeks it really struggled to run right. Never seen misbehaviour until not using TQ 95.
I know mechanics have used other transmission fluids especially when building boxes but old boxes that need a top up or a service are going to have problems with non compatible fluids.
So far researching this problem for 3 months leads me to believe Penrite transmission fluid is the most compatible. But I would still add Lube guard conversion fluid.
Ford Fairmont with 940,000km on it so far trying for the 1 Million.
Old 31-01-2025, 10:46 PM   #71
Unicorn
I guess that those of us with Classic Falcons (0r Maseratis or Ssypong's ) running BTR we better stock up on retailers still have on their shelves.
I think that by next week there will be no stock left.
All Ford wagons up to BF II Wagon use the 4 speed box. Never made a 6 speed version. Those are 17 years old.
The last 4 speed Sedan was probably 2011 which is 13 years old. Their are probably some straight 6 Territory's with a 4 speed box built after that.
To swap a 6 speed into a car with a BTR 4 speed you need a matching ECU Barra and ZF box as they are coded together from a donor car. Plus some engineering for a wagon.
If anyone can get the oils linked previously let the rest of us know and report performance.
https://hi-tecoils.com.au/product/atf-type95/
https://automotivesuperstore.com.au/gulf-western-32042
Gulf Western says approved by BTR, Hi Tec Oils say manufactured to spec for BTR boxes.
Maybe Penrite will work but it is readily Available and the Castrol Max multi might work.
Then comes the issue of not mixing oils as you can not drain the box completely.
Really annoying to have this problem.
Old 01-02-2025, 06:14 AM   #72
Falcon SXR8
I just did a service and full flush on a btr with 200 000ks on it. From what i could tell it's never been done before. Gearbox was working fine and used the penrite oil in it and so far is still going fine a few thousand ks later, so hopefully stays that way.
Had
EB XR8
AU Fairmont
BA MK2 XR6 Turbo
Now
XDUB
6 users like this post:
Old 12-02-2025, 11:39 AM   #73
Jim5_0
Originally Posted by lra View Post
If the the 'correct and recommended' trans fluid is NLA, what are Ford dealers going to use when you get your 4 speed Falcon / Territory serviced at a dealer ?
I doubt if any Ford dealer is interested in servicing a car of that age. I asked my local Ford dealer how much a service on my FGX would cost. "Can't tell you because it's pre 2018. It will be done on an hourly rate not a capped price."
So who in their right mind is going to take pre 2012 Falcon or Territory to a Ford dealer for a service? Maybe someone out in the sticks where the dealerships are smaller and look after customers better.
Jim5_0 is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2025, 09:58 PM   #74
Bill M
Bill M's Avatar
What do the BTR transmission rebuilders recommend?
AUII XR6 VCT ute
20 years and still going strong!
Bill M is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2025, 10:12 PM   #75
EBSXR6
EBSXR6's Avatar
I have a 2013 FG the Ford Dealer quotes me if it's A or B service.
EBSXR6 is online now   Reply With Quote Multi-Quote with this Post
