08-05-2006, 01:51 PM | #1 | ||
Just to prove nothing is really new .. I was reading an old "MuscleCars" magazine last night and found an article on smallblock Fords (written 1990) which detailed a 289 Windsor with SOHC:
"Ford engineers added aluminum cam boxes in place of the valve covers. The cams acted directly on the top of the modified rocker arms. The bump-sticks were driven by a 1-inch Gilmer belt that got it's twist from a crank-mounted pulley ... The result? With single 4-barrel, the engine cranked out 300hp. The 289 'cammer would also spin to 6500rpm with ease. The problem was that even with the additional rpm potential, the heads and manifold simply couldn't flow enough to keep up. Until that disappointment, Ford had intended to market the overhead cam setup as an over-the-counter kit to be installed by car owners looking for a higher level of performance. When the OHC didn't live up to expectations, the project found itself to be shelved." I don't think 300hp from 289ci in the mid-sixties is too shabby? Kind of makes a SOHC 5.4L look under-rated. How cool would a SOHC 289 be in an XR GT?? Sweet!!! |
08-05-2006, 06:09 PM | #2 | ||
Peter Car
Ford had a SOHC 427 available in the 60's. They made around 50 of them, they would have sold more but Nascar banned them from using it so they dropped it. Made around 600+ hp and revved past 7000rpm.
08-05-2006, 08:15 PM | #3 | |||
Detroit Locker Equiped TM
It would certainly have had potential.
Apollo Blue 1974 XB Falcon GT, 557 HP Blue Pearl 2004 BA FPV GT, 290 kW Quote:
http://www.facebook.com/FalconGTClubGeelong |
08-05-2006, 11:00 PM | #4 | ||
building the xe...
i think everyone is wishing they built more of the 427 cammers... except the opposition... hehe
would have been the best motor out... imagine it in a gt40? or a cobra... or even a phase 2 like bil bourkes? hmmm |
08-05-2006, 11:13 PM | #5 | ||
The 289 in the shelby GT350 models was rated at 306hp, the R models a bit more.
The standard ford 289 Hp was rated at 271hp... It obviously wasnt a viable option,otherwise they would have built it. Also the 289's in the GT40's, and cobra's were rated at 385hp, and race ones that were fitted with fuel injection, and guerney westlake heads were rated at well over 400hp. The 289 is a very nice little engine which wouldve been seeing well over 8000 rpm in racing cars back then, the 289 powered GT40's of the day had a top speed of 217 mph. |
09-05-2006, 08:17 AM | #6 | ||
... sounds like the 289 SOHC was basically a stock engine with the conversion .. imagine if it was setup to 289 HiPo specs .. or Shelby-ized??? Great little engines. Very cool ..
09-05-2006, 01:59 PM | #7 | |||
09-05-2006, 04:22 PM | #8 | ||
XW 351
Sorry if this is a dumb question. but how do they convert an engine to OHC, what do they do with the area in the block where the cam use to sit?
09-05-2006, 05:16 PM | #9 | |||
Rod. |
09-05-2006, 07:57 PM | #10 | ||
turboute
They could just leave it empty - as long as the oil returned to the sump there would be no problems in theory.
09-05-2006, 10:54 PM | #11 | ||
rocknrolla
well you would need the cam to still be turning so that the dizzy/oil pump would still be driven. so chances are they just left it there.
10-05-2006, 10:51 AM | #12 | ||||
Exactly! the 289 hp is the hipo!! |
10-05-2006, 11:08 AM | #13 | ||
re
Location: Victoria - where being slow & incompetent is considered being "safe"
There were a couple of aftermarket companies back in the 80’s/90’s that had/talked about an overhead conversion to pushrod Ford V8’s (I can’t remember if they were Windsors or Clevos). I think they had different heads bolted on to the stock blocks. The drive to the OHC was taken by rubber belts (maybe chains) from the front of the crank.
Expensive as all hell – I don’t know what they did with the distributor drive.
Scuderia Rev: Otto the tow pig - 2007 3.0 litre Coupé, vernünftig schnelle aber kein peilstab, Bathurst 2007 und 2010 zwölf Stunde Gewinner Jaffa the angry ant - mid 70's Honda 市民の, 73 と立方インチ LSD Elle "the body" shell - early 70's Datsun フェアレディ coupe. いい体は彼女の内側、内側と土台を待つ |
10-05-2006, 12:53 PM | #14 | |||
11-05-2006, 03:53 PM | #15 | |||
Peter Car
11-05-2006, 04:06 PM | #16 | |||
11-05-2006, 04:59 PM | #17 | |||
Peter Car
11-05-2006, 05:09 PM | #18 | ||
BJ is right though, there were quite a few more the 50 made as they did sell them over the counter as a complete engine (crate engine) aswell.
I dont know the exact figures, but even though they were banned from NASCAR, to qualify them, they wouldve made a minimum number much greater than 50. As BJ said, they were fitted to various different drags cars, nitro funny cars,altereds,AFX cars etc. Would be good to see if anyone knows how many they made. As for street machine..... |
