Old 15-05-2006, 09:50 PM   #1
Whitey-AMG
AWD Assassin
Whitey-AMG's Avatar
Default Can't record SD signal from Digital transmission ??
What is going on here ??
Tried to record a program from my Toshiba DST Box in SD mode on my SONY DVD recorder and got the message ........"cannot record this signal"....... :nutsycuck
Has anyone else copped this as well........Does it happen on Hard Disk Drive recorders as well. Whay has life gotten so complicated......... :
Old RIDE
2006 BFGT
Gone but not forgotten
New RIDE
2018 AMG Mercedes A45
Angry AWD assassin
Whitey-AMG is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2006, 01:28 PM   #2
nobbystang
nobbystang's Avatar
The following forum is pretty good for problems like that if no-one here can help
http://www.dtvforum.info/index.php?
Current:
2016 Camry
1966 Mustang Coupe
Previous:
2011 SZ Territory Titanium
2008 Ford Edge AWD Limited
Silhouette BF XR6, ZF Auto
White EF GLi, XR look alike
VH Commodore
nobbystang is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2006, 02:20 PM   #3
BlackLS
How have you connected them togther?
Old 16-05-2006, 02:45 PM   #4
AU1FORME
Son of Wolverine
AU1FORME's Avatar
Usually get that message when you are trying to capture copyright material
what is it you are trying to record.
Turbo's are great, but I'd rather be blown
AU1FORME is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2006, 03:13 PM   #5
chevypower
chevypower's Avatar
yes, if there is a Macrovision protection (Macrovision only protects on the analog out signal) if two digital devices are connected together the recording device will not attempt to record the signal. if the recording device is analog, it will attempt to record but you will get a bad recording
eg if you connect a DVD player in to a Mini DV camcorder, you will not be able to record the signal (from a movie) message appears "COPY INHIBIT" if you use composite video or S-video, will give u the same
chevypower is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2006, 03:43 PM   #6
MYV8
Gota be happy with a Hump
MYV8's Avatar
The macrovision protection is encoded in the video channel.
Depending on how you have it connected there is ways of cleaning signals which overcome certain problems.
Google is your friend.
P.S. I am not suggesting that anyone should try and copy any copyrighted material.
:BA XR8 Ute Auto (Now with Pump Gears) :
12.756 @ 107.16..........1.915 60'
Genuine Unopened Time
BluePower Racing Developments ............... Best in the Business
MYV8 is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2006, 11:36 AM   #7
Whitey-AMG
AWD Assassin
Whitey-AMG's Avatar
Thanks all for your responses.
My current connections are thus :
Toshiba HD set top box connected to Hitachi Plasma.
STB is also connected to SONY DVD Recorder. STB output to DVD recorder Input.
I can record most programs no problem. However, there are certain programs........FOOTY , some movies , docos etc, where it seems the signal is encoded and cannot be recorded.........
Is this the case with a HARD DISK DRIVE recorder.........can you record any program on a HDD recorder or will the encoded signal also prevent recording on these devices as well.
I imagine that you would still have issues recording the program from the HDD to DVD ????
Old RIDE
2006 BFGT
New RIDE
Angry AWD assassin
