Old 08-06-2006, 01:13 PM   #1
nrmadude
grub screw
Default clear coating pealing off paint
gday all
my 95 futura has this clear coating that has started to peal and flake off a tiny bit just above a door and on the roof of the car.
my qns are, what is this stuff?
how can i fix it?
cheers
NRMADUDE
nrmadude is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2006, 01:15 PM   #2
39ClevoUte
39ClevoUte's Avatar
Probably a fadded paint job that has had a coat of clear many years later to make it look fantastic.
Clear coats done at the same time as full paint job don't do this, unless totaly stuffed up.
Fix it, don't know.
39ClevoUte is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2006, 01:21 PM   #3
nrmadude
grub screw
cheers
yeah ive seen plenty of fords around with this problem, way worse than mine.
id like to stop it before it looks like the horrors i have seen around the place.
Old 08-06-2006, 01:23 PM   #4
EFFalcon
Last warning
EFFalcon's Avatar
average repair jobs can have this done.
if the paints not masked up properly it can leave a small lip that allows the paint to be lifted easy.
once its started its rather hard to stop unless you wanna put some more paint over it.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 08-06-2006, 01:24 PM   #5
39ClevoUte
39ClevoUte's Avatar
Maybe rub back the crappy bits and recoat. This may stop further damage.
Old 08-06-2006, 01:27 PM   #6
EFFalcon
Last warning
EFFalcon's Avatar
thats what i did to my bonnet, still looked average (i did a quick job)
but it was an improvement.
i guess it depends how visible the area is and how bad the peeling is.
Old 08-06-2006, 01:43 PM   #7
nrmadude
grub screw
thanks fellas and sheilas, so what would this clear re-coat stuff be if i went down to my local shops and tried to buy some, just a little tin to dab a bit on the flaked off areas?
Old 08-06-2006, 03:38 PM   #8
LTDHO
The one and only
LTDHO's Avatar
Contact NRMA and get them to fix it..... Ha ha.
Have that section rubbed back and re cleared.
1992 DC LTDHO 360rwkw built by me
Tuned by CVE Performance
Going of the rails on a crazy train
Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
LTDHO is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2006, 05:45 PM   #9
XR8Chic
I swear its all stock!!
XR8Chic's Avatar
When I had my engine bay resprayed a few years back - the idiot lifted up the clear on the top of the guards when he took off the masking tape.
I had it polished by a detailer, and it came up 99% better.
When I got the bonnet vents put in, I got the spray painter to strip the whole front end, and respray... now its 110% better
1993 ED XR8
2006 BF GT
2011 FG XR6 Ute Limited Edition
XR8Chic is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2006, 10:24 PM   #10
finnyman
smoke rubber, not crack
yeh man rub back the whole door with p600 wet, wax and grease the door with a few lint free rags and then 2 good even coats of clear should do it, give time between coats to dry, make sure you rub all the shine off the door b4 clearin it, you want it to adhere well...all done
the roof i would get done by a spraypainter as blends down ur cant rails/quarter panels will need experience for a good result....ciao
finnyman is offline   Reply With Quote Multi-Quote with this Post
