Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
Now that the family has 4 cars coming and going I am looking at adding to the driveway. Currently it has a cement base with a painted stencil pattern on top.
I was thinking of getting gravel or recycled roofs tiles (broken ones, they would match the stencil colour). What I'm worried about is any lose material wreaking the stencil pattern on the main driveway. Has anyone had any experiences they can share using this kind of driveway extension? Uncle Ken
Ideally, the best bet would be to continue the concrete pattern you already have as it will match better in the long run, just make sure it is tied to the exisisting concrete with rebar drilled into the side
Otherwise, you could use a terracotta concrete paver or clay pavers that match in with it. All depends on cost of course. You could also put in a crushed rock base with a matching gravel on top, which would be the cheapest option and if compacted right would do a relatively good job |
#3 | |||
Uncle_Ken
#4 | |||
Audi S3
#5 | |||
Dont forget without council permission u cant do the driveway on the crossover, it has to be in your own yard. |
Thanks HLC, 1TUFFUTE,
Do you think the lose material would wreak the existing driveway? I'm worried about the stencil paint finish. UK
FTF Club Moderator
I dont know if the loose material would affect the existing driveway, but what about your wheels. Broken terracotta can be sharp.
Albert Einstein: Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom. (It is more difficult to alter a preconception than split an atom) Falcon Tickford FPV (FTF) Car Club of NSW Fords in the Park 2010 I use and recommend Stingray Car Security. http://www.stingraycar.com.au/ |
#8 | |||
The stencil pattern was applied by a spray method years after the original concrete was put down.
UK
dig in a sleeper between the concrete and the rocks. Use fine rocks and COMPACT them and u should be able to keep them off the driveway mostly. Paint like that will always start coming up anyhow but thats your best bet id say.have a little step down and no rocks should come up.
Cracker dust and coloured cement.
FORD RULES OK The more I know ppl the more I love my DOGS. 2011 SY Territory Limited Edition TS 2000 AUII SE ute IL6 |
#12 | |||
