Old 08-07-2006, 07:08 AM   #1
RG
Back to Le Frenchy
RG's Avatar
Default EL headlight removal.
Hey guys, I need to get my drivers side headlight out (low series EL) and wouldn't have a clue how. I've got an EF service manual and it says that you have to remove the bumper, is EL the same or is there a way around dropping the bumper?
Cheers.
Old 08-07-2006, 07:31 AM   #2
peak revs
peak revs's Avatar
I know you have to drop the bumper, a panel beater mate told me that - sorry for the bad news.
peak revs is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2006, 10:40 AM   #3
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
No you dont have to drop the bumper bar unless it is different on Fairmonts as my mate removed mine without dropping the bumper bar.
Of course you have to remove the indicator housings first.
Its just a bit of a squeeze and fiddle to get them out and you have to push the bumper bar down which sits below the headlight whilst removing them as they get caught there.
But they are plastic bumper bars so they bend....
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Originally Posted by rednose View Post
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2006, 10:43 AM   #4
LUXO_8
windsor user
it is different on the fairmonts and you dont have to drop the bar on a fairmont and you can get away with just undoing the clips at the top of the "grille" area on an EF, but you do on an EL due to the headlight having a slightly "shorter" lens, the front bar covers the light too much to get at it...
you dont have to remove the bar completley, but you have to undo the side your wanting to get out....
Old 08-07-2006, 11:24 AM   #5
RG
Back to Le Frenchy
RG's Avatar
Ahhh bugger, now how do I undo the bumper?
Old 08-07-2006, 11:46 AM   #6
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
remove the black plastic cover from between the lights, disconnect the horn wires if you remove the whole bar, undo the front half of the splash gaurd in the wheel arch, turn the bumper side supports 90* and then remove the large bumper retaining nuts.
BENT_8 is online now   Reply With Quote Multi-Quote with this Post
