14-07-2006, 04:26 PM | #1 | ||
Next upgraded Mk1 Leopard
Hi all,
The boys Eb is making a high pitch squeal noise after I fixed the front end. Its quite when at idle, put when he drives it it make the noise, Sounds like its coming from the fan belt. What have I done wrong? Uncle Ken
14-07-2006, 04:49 PM | #2 | ||
Shoot.
Does it happen more-so when you put load on the electrical system? Could be as simple as a loose belt.
20V Turbo |
14-07-2006, 05:40 PM | #3 | ||
spray a bit of CRC on the belts
14-07-2006, 06:12 PM | #4 | ||
V8 Powaah
Seized fan belt tensioner ?
FG G6E Turbo- Seduce & Cashmere - Sold XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
14-07-2006, 06:57 PM | #5 | ||
Sounds like a loose/worn belt to me, usually the alternator belts go on them. try tightening it first and if it still does it then buy new belts for it.
14-07-2006, 07:43 PM | #6 | ||
could also be the bearings in one of the idler pully's. They always go. And btw, it's not a good idea to spray CRC on the actual belts, it will only make them slip. Spray it on the center of the pully's where the bearings are.
15-07-2006, 05:19 PM | #7 | ||
Thanks for the thoughts guys. The EB lights went out last night. My son called me up, I had to jump start it to get it home. Luck for him I picked up an alternator from the wreckers when I was replacing the water pump. I changed out the old one and now everything seems OK. I have just go back from taking the car for a long run. No belt noise, battery seems to be charing. Xrated I put on new belts last week. Hope fully the replacement alternator will do the trick.
Uncle Ken
