Shockworks
Old 03-08-2006, 04:52 PM   #1
simonr
Focus Rookie
simonr's Avatar
Default eBay: Powerchip for a 1.8
http://cgi.ebay.com.au/ford-focus-1-...QQcmdZViewItem
Legit?
how much do they retail for?
04' Panther Black Focus Zetec
Custom Euro Plates, ST side indicators, MK2 Badges, ST Snorkel, White 17"s, Exhaust, Springs, Volant Intake,Angel Eyes, Body Kit, St170 Lower Grill, F/C Throttle Body, DBA slotters
simonr is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2006, 07:14 PM   #2
FRA
Mr Focus
FRA's Avatar
I've just been to the www.powerchip.com.au
Your Ford Focus 2.0 uses a specially manufactured Ford computer, unlike any other vehicle manufacturer. The Powerchip is a plug-in board which plugs into an edge connector on your computer. Once installed the Powerchip will override the settings from the computer, and improve performance. To return the vehicle to standard settings, simply un-plug the board from the edge connector (making sure the ignition is OFF). Fitting is easy and can be performed in about 30 minutes with full colour fitting instructions, including pictures. The Powerchip is available by next day courier.
In standard form, the Focus 2.0 produces 85 kW and 162 Nm.
Powerchip has a range of chips to suit your car, which can increase it's power to between 92 kW and 95 kW, and it's torque to between 176 Nm and 181 Nm.
The price of the Powerchip is AUD $890.00.
I find it hard to beleieve myself, I'll call them tomorrow and see what answer i can get.I they can get 15Hp+ I'll buy 2 of them...lol
Hers there number.
Phone: (03) 9681 6888
Fax: (03) 9681 6777
Cosworth: 2.5" high flow exhaust system, piston & rod 8.5.1 Ford Racing: Tail lights, engine cover, racing wing, cnc'd head, manifold, 70mm tb. Lentech: Torque Convertors with 23 spline input shaft, valvebody
Oz racing: WRC OBX: 4-2-1 race header
SCT: xcal3, dash scan.
FRA is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2006, 10:28 AM   #3
FRA
Mr Focus
FRA's Avatar
Just got off the phone to powerchip.
This chip is only good for nearly stock standard, like if you have upgraded the exhaust or air intake then that's ok.
People like me who are rebuilding a engine, this chip isn't for you.
In standard form, the Focus Zetec 2.0 produces 96 kW and 178 Nm.
Powerchip has a range of chips to suit your car, which can increase it's power to between 105 kW and 107 kW, and it's torque to between 194 Nm and 197 Nm.
Old 08-08-2006, 08:21 PM   #4
amlohac
amlohac's Avatar
But you can get powerchip to custom program a chip for your needs, of course this all comes down to how much cash you have to throw around.
amlohac is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2006, 09:55 PM   #5
FRA
Mr Focus
FRA's Avatar
I'll have to ask powerchip that.
No point getting this chip until I get the turbo
Old 19-08-2006, 12:03 AM   #6
Uni
in which case you'd probably be better off with stand alone management anyway, particularly if you're aiming for the sort of horsepower you say you are ;) not so much because the chip won't be good, but simply because of the variety of tunes available on a stand alone system, readily accessible at any given time
Uni/.
Uni is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2006, 01:27 AM   #7
zetec
Zoom Zoom
zetec's Avatar
Agree with Uni. You'd be best looking for a more custom tune chip FRA.
Powerchips suit exhaust and filter kind of mods and nothing more. They're also a waste of money at that price... until recently they didn't even have Powerchips for the 2.0 LR Zetec, must be a new thing.
2012 Mazda3 MPS
Old 20-08-2006, 07:45 PM   #8
melbzetec
Old enough to know better
melbzetec's Avatar
For big power upgrades you should look at the Pectel engine management system. They have one that plugs straight into the factory harness
Old 20-08-2006, 08:48 PM   #9
FRA
Mr Focus
FRA's Avatar
I will get the Pectel engine mangement system but, it come with a big price tag.
It'll be worth getting for sure.
Old 21-08-2006, 01:11 AM   #10
amlohac
amlohac's Avatar
turboing a car comes with a large price tag in general
Old 21-08-2006, 02:05 PM   #11
2uningFoci
Zetec2.0
2uningFoci's Avatar
Alot of guys are using Megasquirt Ecu's in the UK with their Turbo Zetec's. You can get a setup for about $600.00aud with wiring loom, check out their website.
2uningFoci is offline   Reply With Quote Multi-Quote with this Post
Old 26-08-2006, 04:57 PM   #12
FRA
Mr Focus
FRA's Avatar
I don't know how good it'll be for me with the setup I want in the end.
Pectel engine management system is what I want for my setup but, it'll be a good year before I even think about getting it.
Crane cam Ignition is another thing I want.
The powerchip is the best 1 I have seen for near stock engine.
I think I saw you on Friday afternoon on the northside of town, if it was man nice looking focus.
