Old 20-08-2006, 01:12 PM   #1
xd??
xd??'s Avatar
Default 350 holley
I know this isnt the right place to have this topic, but i thought if i started it in the 6 cyl workshop it wouldnt get as many replies.
Can anyone tell me what screws on the 350 holley are the mixures and the idol screws? pictures would help me also.
Cheers in advance
xd?? is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2006, 01:35 PM   #2
nitroman
nitroman
nitroman's Avatar
The screws each side of the metering block behind the float bowl are idle mixture screws. Turn them both in all the way then undo them 1 1/2 turns as a starting point and then screw them in or out until it idles best. There is a plug on the side of the float bowl to check float level (fuel should just dribble out with the plug out) that you adjust by loosening the big screw on top of the float bowl and turning the 5/8 nut to raise or lower the needle and seat. The screw on the throttle butterfly controls idle speed. They are simple but temperamental, so let us know how you go.
nitroman is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2006, 02:00 PM   #3
xd??
xd??'s Avatar
cheers man, will try soon
