Old 22-08-2006, 01:19 PM   #1
mandrake900
Default TX5 Wiring
Just bought an 87 tx5
It has some electrical issues
The instrument light does not work and the rear lights keep blowing the fuse witch suggests a dead short some where I realy need a wiring diagram or someone that has had and solved this problem -thanks-
mandrake900 is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2006, 08:38 AM   #2
dirty hands
Over Thinker
dirty hands's Avatar
rear light is a common fault the setup has several cluster switches any one of them mah have an internal fault the earth should be red /white stripe the power side red /black stripe
instrument light if not the bulb the bulb carrier or the copper contact on the printed circuit or dry or broken solder points in the main loom of that instrument cluster
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
Old 26-08-2006, 12:36 PM   #3
dirty hands
Over Thinker
this is just a tx5 site might help. http://z3.invisionfree.com/tx5/index.php?
