Old 27-08-2006, 09:45 AM   #1
elusiverunner
elusiverunner's Avatar
Question Tough Nut
I apologise if I am submitting this thread to the wrong Topic. I have a tow bar on my Fairmont Ghia and I want to remove the tow ball. I have dowsed the nut with WD40 and am using the biggest wrench I have - I do not have a breaker bar. I still can not budge the nut and I have tried everything in the way of leverage that I have at my disposal. :
I do not want the destroy the nut or the tow ball as I will most likely need them again. I just want to remove the tow ball to install a shin guard. Any suggestions would be most gratefully accepted. :
BF Fairmont Ghia MKII
2007 Fairmont Ghia MkII. Ego in colour
4 litre 6 Cylinder, ZF 6 speed transmission.
Bolle Window Tint - fitted by Tint a Car
PWR Heat Exchanger, PWR Auto Transmission Oil Cooler - No milkshakes in this car.
After market DRL.
Custom fitted gauge holder with three gauges - Stav of Stingray Car Security.
elusiverunner is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2006, 10:02 AM   #2
tex
Broken
tex's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: With the exception of maybe HSE2, nobody writes a review like Texy.
Try some heat.
But, they're dirt cheap, so buy a new ball .........
The Scud GT
11.4 @ 128, 1.88 60ft.
tex is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2006, 10:07 AM   #3
protd
TUFF FORDS
protd's Avatar
mate use a oxy and try keep the heat on the nut.. as abouve they are cheap any how.. and i know this sounds silly but are you turning it anti-clockwise its easy to not realise especially when your looking down on it then you can get it mixed up.. not saying your doing it wrong but a easy mistake when looking at the blot from the other way..
protd is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2006, 10:15 AM   #4
pertuan
Focus on my Focus
Try getting a pipe to extend the wrench handle. The longer the handle, the more torque you can apply, the easier it will to move the nut... or shear it off. lol
Now: 2006 Ford Focus LX Manual in Satin White
Wife: 2013 Kuga Titanium in Frozen White
Then: 1990 Ford Laser - Assasinated by a 76 year old man who failed to give way.
Now normally when we have these races, Jeremy goes in the car and says "Powerrr" alot.... - James speaking about Jeremy (Top Gear S7 E05)
American parts... Russian parts... ALL MADE IN TAIWAN! - Russian guy in Armegeddon
pertuan is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2006, 10:17 AM   #5
Polyal
The 'Stihl' Man
Polyal's Avatar
lol
I tried this yesterday, and semi rooted the nut, so when the car goes in for a service next Ill get them to do it...lol
I dont have any power tools and I didn't want to stuff it up anymore.
  • 2017 Toyota Prado (work hack)
  • 2017 Mitsubishi Pajero Sport
  • 2003 CL7 Honda Accord Euro R (JDM) - K20A 6MT
  • 1999 Lexus IS200 - 1G-FE Turbo 6MT
  • 1973 ZF Ford Fairlane
Old 27-08-2006, 11:31 AM   #6
ORESUMSR
Legless Old Fart
ORESUMSR's Avatar
Those tow ball nut are pretty big, so why not use a ball pein hammer and solidly tap on every flat side a few times then use your wrench and repeat the process over and over. This will usually crack any rust bead in the thread.
A normal carpenters hammer would also do the job if a ball pein one is not available.
This method will soon get you blacksmiths biceps if nothing else. lol.
ORESUMSR is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2006, 12:44 PM   #7
Ruger
Bseries Moderator
Ruger's Avatar
just get a big pole on the end of a good qual ratchet and itll come off dont be afraid to get the hammer out thats one thing mechanics are good at
Long Live the Rugerspeed Primer Destroyer!
Only those that attempt the absurd achieve the impossible.
Serviced and maintained by Mascot Auto Repairs
Ruger is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2006, 02:22 PM   #8
jd dad
Dont use a ratchet, easy way to go A over T when they let go. Get a decent breaker bar or T handle and use a bit of pipe on that
successfull trades with davway,ozziechief,Damon, Big Trev, Howey, BJ , Niko, Davocol,klawsterfobik and XCwillo
jd dad is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2006, 02:45 PM   #9
HOON69
HOON69's Avatar
mate get a extension bar and give it another go
extension rubber + rubber mullett normally fixes it
HOON69 is offline   Reply With Quote Multi-Quote with this Post
