#31 | ||
what you need to remember is cheap helmets are made from plastic and even worse most have a join down middle, (usually covered by large stick on murals) these i have seen split down the centre, so not worth touching ,I dont even know how most sub $150 ones even pass the Australian design rules.
Hervey Bay QLD Great trades recently- GILMORE BOSSYONBIKE |
#32 | |||
Clevo Mafia Inc.
![]() Join Date: Dec 2004
road race while still having good protection. |
#33 | ||
MO & pertuan have hit the nail on the head so to speak, pun intended. I personally would not risk it, head injuries should not be taken lightly.
#34 | ||
Having been in several “get off’s” on two wheels, I can testify that you pays for what you gets… There is only one way to buy a helmet, go in to a reputable shop (be it motor sport or motorbike) and try on all the different brands and styles that are available until you get one that fits you.
In a previous post it was mentioned that helmets develop a kind of “memory” when they start to conform to bonce inside them. Totally true, but also certain helmets fit certain heads. My big fat head is very comfortable in only one brand. I’ve tried dozens of different brands and found that I could never fit into some and was only comfortable in one. They weren’t cheap but what price my life??? On one of my rubber side up excursions, my helmet took a fair beating, I’m sure the only reason I’m here today is because of it. Anyway a group of my mates decided we needed to celebrate my survival and we had a little party. Before long the engineers and scientists were pulling my not that old but well and truly worn out helmet to bits to see if they could see any internal damage. Oh yeah! Although the fibre glass / composite shell had only what looked like superficial damage (360 degree scratches and marks), there didn’t appear to be an impact point. But when we ripped the foam inner liner out it was very clear that there had been a very major impact. The helmet was toast and the right decision was to have it destroyed. I still ride and I have a selection of full face and open face helmets that I wear depending on the situation. Facial damage & chins ripped off with open face? Jaws & teeth smashed to bits with a full face? Just remember that without a helmet you’d be in a coffin most likely. The choice is yours, choose wisely. |
#35 | ||
What is your head worth is the question?
Mine's worth more than a cheap hat..... I have a kevlar one and I know that whilst funds can always go in other places this is one area that I believe should not be shortchanged, also their are differences between motorcycle helmets and thoses designed for car racing...... Just some thoughts |
#36 | |||
Stu, out of curiosity, you say there is a difference between the motorcycle and car racing helmet.. so does this mean that those coming to the Qld event and doing the track work need a car racing helmet - or is a motorcycle style one ok?? I have asked this question to the person that will be checking ever single helmet on the day but have not had a reply as yet.. Would appreciate any information from anyone that is in the know on this.. Thanks Kerri |
#37 | ||
I beleive a motorcycle helmet will be fine, some motor bike helmets have a larger openeing on the full face helmet to alow for better vision, it does not seem important until you are using a car helmet with a small opening on your bike and trying to tuck down behind the screen looking out a very narrow opening. Also some M/C helmets are shaped for airflow purposes
Pit Lane Performance 20 Rosella St Frankston 03 9783 8122 Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
#38 | |||
Grinder+Welder = Race car
Motorcylce helmets typically have vents etc to provide airflow to the riders head, while in a closed car these vents are next to useless. High end single seater helmets are often shaped differently to anything else for aerodynamic reasons. Finally, one of the major distinctions is that Motorcycle helmets are not set up to be fitted with a HANS device, while many car helmets are (And in 2011 HANS device use will be mandatory in CAMS sanctioned events). Basically if a Bike helmet has marking indicating it meets one of a list of about 10 different national standards (my CAMS manual is a few years out of date, so rather than post potentially misleading info, hopefully someone with an up to date copy of the NCRs and can post them?), then it acceptable for circuit use, although if its a FIA sanctioned event theres a shortened list of standards the helmet is required to meet.
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear" - Too much power is never enough....Mark Donohue on the Can Am Porsche 917. |
#39 | ||
V8 wannaabeee
brand spank'n new open face helmets go for around $100/$150 and they look good...
new motox helmets are freak'n like $300 !!! i was like come on... it's only a helmet with an australian approved tick :( |
#40 | |||
$300 is still cheap, you can easily spend over $1100 for a decent helmet
#41 | |||
Former BTIKD
![]() Join Date: Mar 2005
Hell if you just want to look good, buy a beanie and paint it!
#42 | ||
I am gathering that some that are saying about buying a cheapish helmet are actually talking about a helmet they would use for track work every now and then.. maybe the drags every few months etc..
I am unsure but would think people riding a motorbike would take far greater care in their choice of helmets... Just the way I see it, and I could very well be wrong.. Mind you, some people riding a bike need a better helmet if some of their riding on the roads is anything to go by.. |
#43 | ||
Hello
My kids have brand new, rather expensive helmets for riding their pushbikes, since they ride 6 km per day, to and from school, every day. On busy roads, with a lot of cars. They also have good bikes with reliable gears and good brakes and tyres, the bikes are always serviced... but that is another point.
For drag racing, my kids have their own full face, motorbike helmets. $200 each or thereabouts, brand new. Had them fitted for them at Yamaha World here in SA. I have worked as a nurse in a large ED in a large public hospital on nights at weekends, and have seen the effects of motocycle accidents, particularly those who didnt wear a) helmets at all b) open faced helmets and c) crap/if any decent leathers. The injuries for bike riders compared to car drivers in an identical accident are very serious, so its very important to maximise all the protection you can get, as far as I have seen. No metal shell surrounding you, no airbags... may as well spend the money you saved on a car on good safety gear for the bike. Im not big on second hand anything, just personally.
2008 FPV TERRITORY F6-X Silhouette, window tint, roof racks, 3rd row seats, ROH Mantis 19s, black custom plates 'FPVF6X' and no stripes. ![]() ![]() |
#44 | |||
#45 | |||
That was the point I tried to make!!! |
#46 | ||
OK my final word...buy second hand RISK your life...buy new and be safe.
FORD RULES OK The more I know ppl the more I love my DOGS. 2011 SY Territory Limited Edition TS 2000 AUII SE ute IL6 |
#47 | |||
If not well............you know the rest.
#48 | |||
Former BTIKD
#49 | ||
Solution Was Boost 4?, 6 & 8
lets keep the discussion about helmets.
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED 2017 GT Mustang Plenty of RWKW |
#50 | ||
Ute Forum Moderator
Fiery the motorbike helmets are cheap! You could pay as little as $100 for a full face helmet, although I believe it is worthwhile spending a little extra for a better grade of helmet than one that "just" passes the Australian Standards. That's what I did for use at the drags etc, mine is a full-face that cost $180 or $200. If I was going to do more competitive stuff on the racetrack I would be getting a "proper" racing helmet and would look seriously at the Hans device, given that if the hit is hard enough it is possible to headbutt the steering wheel even when wearing a full harness.
#51 | ||
As said before, to save 100-200 bucks by purchasing a second hand helmet is dangerous as you don't know its internal integrity and its capacity to save your brain from a pummelling. You can't place a price on your life or the condition of your brain, which adversely will affect your quality of life. Being a veggie isn't fun!
Buy a new helmet. Sure, it may not be cheap, but at least you'll be on the road confident that should you have an accident, your brain won't end up being pickled. I think that's all that needs to be said. |
#52 | ||
1.3 Litre Suzuki power
There are plenty of bike shops around that have sales on Helmets. All new helmets in Australia have to meet the Australian standards and have the approved sticker attached.
As I ride I brought a Suomy Spec 1 R which cost me 750 bucks. I tried on a variety of helmets and found for my head shape the Suomy and Shoei where the 2 helmets which were firm, but comfortable. You could try websites like HERE Check the red hot specials or you can go further and check the road apparel for the whole range of helmets. I would not buy a helmet without trying it on first. Imagine buying a helmet, it's tight and uncomfortable and you have to spend a day on the track. Will you be able to concentrate 100% with the helmet is uncomfortable.
BA series II XR6T in Blaze July 05 build. Stock as a rock EF 4lt 1995 in Green on LPG. To and from work hack. XY Fairmont 1971 in Bronze Wine, 302, Top Loader, 9" Still trying to find out if she is a GS or plain jane Monty. Mustang 1966 coupe, Silver frost, A code, C4, factory bench seat, A/C, P/S rally pac, AM radio with 8 track. Awaiting funds for resto. K6 Hayabusa....Dead Stock and why would one need to spend thousands on mods................. |
