Old 28-08-2006, 08:19 AM   #31
Eaturbo
BUILT FORD TUFF
Eaturbo's Avatar
The rear boot garnish wa painted white to make it a bit more unique as you never see them painted and also i converted the rear to an EB rear end. I got the garnish for free and it was damaged so we cleaned it up and painted it. In all i love the look and would do nothing different if i did it again.
2015 FGX XR6 Turbo
Eaturbo is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2006, 08:29 AM   #32
dansedgli
dansedgli's Avatar
How does the boost cut work? Is it a function of the microfueler?
My car made less power on 13psi than it did on 12. We figured there was a restriction somewhere, could it be the boost cut feature, I have an aftermarket microfueller?
Are you using a stock manifold that is modified for the T04Z?
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2006, 10:13 AM   #33
sven
sven's Avatar
really like the car. maybe if you get bored you could drive down for the cruise on the 16th!!!
ED XR8
sven is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2006, 10:19 AM   #34
Eaturbo
BUILT FORD TUFF
Eaturbo's Avatar
The boost cut is not part of the microfueler, it is a little black box that is wired into the map sensor wires down near the computer. Yours would have one being stage 2 unless some idiot has removed it. If you dont have one, at around 12psi it will shut down like someone has switched the key off. The boost cut box intercepts the signal from the map sensor and lets the signal reach 11psi and then clamps the signal at this point and wont let it go any higher, the computer only sees 11psi even at 20psi and so all is good no engine cutting out. All it does is trick the computer which is what all these little boxes do on all japanese cars. Check to see if you can see a steel plate between the block and head with head gasket either side, it should have one or someone has removed it when doing a head gasket
2015 FGX XR6 Turbo
Old 28-08-2006, 10:21 AM   #35
Eaturbo
BUILT FORD TUFF
Eaturbo's Avatar
Would love to but have sold the car to make way for a EB GT which is great but only has half the power
2015 FGX XR6 Turbo
Old 28-08-2006, 10:33 AM   #36
EA2BA
PM me if you want
EA2BA's Avatar
Nice body kit, front and rear bar look familar.
308kw nice bit of power you got there.
Owner of first ever car to retrofit BA SSS - the EA2BA
Send me a PM if you want to know anything
2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
EA2BA is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2006, 11:47 AM   #37
DEVL-XR
EBII XR6
DEVL-XR's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Writing tech article(s)
Originally Posted by Eaturbo
photoshopped my ***, every bit of this car has been built,brought,welded,screwed,bolted,clamped,wired, soldered,painted,adjusted,broken,replaced,busted knuckles,squashed fingers, by me and me alone, tell me which part do you think have been photoshopped.
between the twinlights and the grille, theres a darker black line, which is why i asked if it had been photoshopped!i think that was it!
by the way tell me bout the lights and the cosworth bonnet vents!!!
DEVLXR
DEVL-XR is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2006, 11:51 AM   #38
Eaturbo
BUILT FORD TUFF
Eaturbo's Avatar
Yeah rear bar is a golden oldie from the 80's when EA first come out and the front one is a SSV VN Group A style one which was bigger to allow more air in. Now just need to stroke the GT to get some more grunt
2015 FGX XR6 Turbo
Old 28-08-2006, 11:55 AM   #39
Eaturbo
BUILT FORD TUFF
Eaturbo's Avatar
The headlight are twin lights and are only there because we made the intercooler to big and then couldn't fit the headlights back in so had to trim some of the fibreglass away to fit these ones,have a look at the second lot of photos with the bonnet open and you can see the left headlight has been trimed near the intercooler, the cosworth vents are genuine ones and are made of cast aluminium and i have never seen another pair the same as they are usally fibreglass
2015 FGX XR6 Turbo
Old 28-08-2006, 04:59 PM   #40
NC_Lane
NC Fairlane Ghia
NC_Lane's Avatar
Very nice.....The white goes with the kit really well
NC_Lane is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2006, 07:25 PM   #41
Eaturbo
BUILT FORD TUFF
Eaturbo's Avatar
Default dyno graph
here is the dyno graph
2015 FGX XR6 Turbo
Old 28-08-2006, 10:03 PM   #42
Rollin
Rollin's Avatar
That looks hot man! and I'm so envious of your dyno graph!
Rollin is offline   Reply With Quote Multi-Quote with this Post
