05-04-2006, 11:38 PM | #151 | ||
Chairman & Administrator
It's still there - when searching by part number you need to make sure you leave the spaces.
Cheers Russ
Observatio Facta Rotae
02-05-2006, 03:43 PM | #152 | ||
Russ,
I'm not so sure, but on the AU's i think there was a "Dome Light" Fairmont/Fairlane Button. Warm Charcoal. It's exactly like the Traction Control Button, 1/2 Height Antenna Button, except it is a "Dome Light" Button. Otherwise if there is a Button, with a "Fog Light" Icon. That'd be good to thanks.
02-05-2006, 09:27 PM | #153 | ||
Au2 15k218 A Switch Fog Lamp, 4 Dr Sed, (-)xr 61.90
Au2tve 13713 B Switch Courtesy Lamp, (forte/xr With Police Pack Or 4 Dr Sed Futura With Police Pack) 36.90
02-05-2006, 10:40 PM | #154 | ||
Champ!
27-05-2006, 09:38 AM | #155 | |||
:eclipsee_ MY CAR :eclipsee_
27-05-2006, 09:48 AM | #156 | ||
No - the mats are just the usual AU mats with each variant having their respective logos in the lower left hand corner.
Cheers Russ
27-05-2006, 09:53 AM | #157 | |||
27-05-2006, 10:06 AM | #158 | ||
About as well as anything Ford does is fully moulded.
Russ
29-05-2006, 10:51 AM | #159 | ||
T3/Sprint8
Hi Russell,
I don't know if this has been asked before but I want to replace all my radiator hoses's,heater hoses's, heater by-pass etcetc OE part numbers would be great,this is all to suit a 2002 TS50. Thanks very much in advance.
Tickfords T3/TS50 '02 Sprint8 manual Sept 24 '16 Daily Macan GTS "Don't believe everything you read on the internet. Abraham Lincoln" Last edited by FTE217; 29-05-2006 at 11:35 AM. |
29-05-2006, 11:41 AM | #160 | ||
These are no different than any other AU V8
Heater ER 18472 C ER 18472 B ER 18472 D (you need 2 of these) Radiator ER 18472 A ER 8260 C ER 8286 A Overflow bottle: ER8W 005 A ER8A 365 A V 890 115 S 485 A Cheers Russ
29-05-2006, 11:46 AM | #161 | ||
Adapt or perish...
Just a pointer here guys
ER F03512 B1 is obsolete. I contacted three different Ford dealers in my area and they all gave me the same answer, that it's not being made anymore. I'd also assume that ER F03513 B1 would be in the same boat, however, there was one (1) only available in a Brisbane warehouse.
Carless
29-05-2006, 11:52 AM | #162 | ||
T3/Sprint8
Great service Russ thanks mate.
31-05-2006, 12:25 PM | #163 | ||
T3/Sprint8
Russ here's another for me, Boot Cargo Net part number and anyone got idea of cost ?
31-05-2006, 09:59 PM | #164 | ||
ER F46042 A BAG CARGO NET, (4 DR SED FAIRMONT/GHIA OR FAIRLANE/LTD) $64.40
Cheers Russ
31-05-2006, 11:12 PM | #165 | |||
Cheers, Phil |
01-06-2006, 01:41 PM | #166 | |||
T3/Sprint8
20-06-2006, 02:43 PM | #167 | ||
Trying in vain to find part number and cost for coolant overflow tank i think its called(white plastic thing looks like honeycomb).If anyone can help that would be great.
My Ride
2005 BA MKII F6 Typhoon- details soon. |
20-06-2006, 07:39 PM | #168 | ||
Got to love Ford terminology:
ER 8A080 A - TANK RADIATOR SUPPLY, LESS LOW COOLANT SENSOR, FORTE, 4.0L SOHC EFI 6 CYL (MP) 53.10 ER 8A080 B - TANK RADIATOR SUPPLY, WITH COOLANT LEVEL WARNING, WITH TAXI/POLICE PACK 95.90 Cheers Russ
25-06-2006, 03:55 PM | #169 | ||
Russ, I can't find anything to do with the Havoc.
I'm trying to find the Driving Lights/Lamps. Do Ford sell them? Or where can I buy them? Do Hella or Narva make them? Thanks
25-06-2006, 06:42 PM | #170 | ||
The only listings I can find for the Havoc are the unique towbar assembly and the Havoc badge. However a little bit of detective work tells me that the following part is indeed the correct one:
AU2 15200 A 87.70 Cheers Russ
25-06-2006, 06:44 PM | #171 | ||
Thanks, I checked that one... Wasn't to sure about it.
18-07-2006, 10:20 AM | #172 | ||
Hey Russ, I'm wanting for find out whether there are 2 types of air conditioning compressors in the AUs - one for the I6 and one for the V8 - or whether the one pump does both. Have looked under "air" "compressor" and "pump" with no luck?
Thanks, Richard |
18-07-2006, 02:26 PM | #173 | ||
Just did a search using compressor, and came up with the following:
Part # Description Unit Price 1F1Z 19E889 AA RING - SEALING, FOR COMPRESSOR MANIFOLD PORTS, GREEN $6.60 F7AZ 19589 DA OIL A/C COMPRESSOR, POLYALKALINE GLYCOL OIL, SPEC: WSH-M1C231-B $53.00 RMER 19D629 A COMPRESSOR AND CLUTCH ASSY, ALL $448.00
18-07-2006, 06:47 PM | #174 | ||
That is correct I gather - they are all the same.
Cheers Russ
18-07-2006, 07:55 PM | #175 | ||
Yep problem solved - thanks for the help!
29-08-2006, 11:05 PM | #176 | ||
Hey russell
After the part number for a Fan Belt Cover for my AU Futura. Refer to the below thread for more info. Thanks http://www.fordforums.com.au/showthread.php?t=63095
29-08-2006, 11:30 PM | #177 | ||
ER 8146 A SHROUD RAD COOL FAN $69.10
Cheers Russ
29-08-2006, 11:42 PM | #178 | |||
Can u get any with Tickford or anything written on it ? or is it just blank ?
30-08-2006, 09:25 AM | #179 | ||
Just blank.
01-09-2006, 11:41 PM | #180 | ||
Hey Russ
Whats the part number for the AU Series 1 Mudflaps Does the part come with all screws etc needed, or are they seperate, and if seperate what item numbers Jeff
