Old 30-08-2006, 02:13 AM   #1
Edd
Edd
Question steering wheel change!!
hey, anyone know how to change a steering wheel on a 1983 ford laser. ive bought a universal sports one and just wondered if its different to other cars or will it fit straight on?
cheers
Edd
Edd is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2006, 02:35 AM   #2
Professor Farnsworth
Fossil fuel consumer
Location: Mod For: Pub, Bar, Sales Yard, Show 'N Shine, Photoshop, AU to BF, FG to FGX, Territory & Sports Bar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Many years of valuable contributions to the forum, including some superb build threads.
cheers
Edd
if it's universal i don't see there being any problems - there will most likely be a nut/bolt behind the horn pad of the wheel, and possibly 1 or two on either side of the steering wheel (to the left and right of the horn area). It should be a simple process of removing the horn pad (if the horn is in the centre of the wheel) and unbolting the wheel, removing, then bolting the new wheel on. You'll have to re-align the horn switch too. That's some general advice, i don't know the specifics of Laser's in detail. I'm also guessing an 83 laser doesn't have airbags ;p
If you're unsure about the specifics, plenty of places will fit a wheel for you for $30 give or take a bit. Good luck with it.
Professor Farnsworth is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2006, 11:46 AM   #3
VippiN
What a performer!
VippiN's Avatar
Sports steering wheels require boss kits - You're after the one from 1981 Laser to 1989 Laser as they use the same fittings. Grab one from Repco/Sprints etc for about $30.
1981 Ford Laser KA :: E5 :: 2002-2003
1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW
1990 Ford Laser KF TX3 :: BP :: 2010-2011
1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW
2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW
1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020
2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-*
1998 Ford Falcon AU XR6 :: HP Intech :: 2021-*
VippiN is offline   Reply With Quote Multi-Quote with this Post
