Old 15-05-2006, 11:41 AM   #1
drubie
drubie
Default Dead EL climate control display
1998 EL Fairmont.
Is there a common / easy fix when your climate control display gets very, very dim? Can barely see the numbers and only when it is very dark. All the buttons seem to be working OK.
I see them on Ebay for around $200 - fair price?
cheers,
dave.
1998 EL Fairmont, 1975 Alfa Spider Veloce, 1982 Alfasud Ti, 1982 Jeep Cherokee V8
drubie is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2006, 12:53 PM   #2
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Or you could change the light globe in it ;)
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2006, 12:57 PM   #3
harpsta
I6 LICKS
harpsta's Avatar
just change the globe mate, might aswel put some blue LED's in there instead.
harpsta is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2006, 01:01 PM   #4
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
you didnt dim it by accident did you?
the dash light adjuster also dims the climate control display.
well, thats an assumption, does in my ED!
BA MK2 XR6T
ON_DUBS is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2006, 01:30 PM   #5
drubie
drubie
Can't be that simple can it? How do you get the climate control panel out of the dashboard to change the globe? Is it just backlit all the time?
cheers,
dave.
Old 15-05-2006, 01:32 PM   #6
drubie
drubie
No - I checked that. When we first got the car I could hardly see the instruments at night. Took a while to work out how the dash brightness adjuster worked (for an idjit like me anyway). Had to read the manual :-)
Old 15-05-2006, 02:23 PM   #7
NZ
NZ's Avatar
cheers,
dave.
You need to take off the dash surround. Its not hard, theres three screws above the cluster, 2 above you knees, and a couple near the radio. You'll see how the climate module comes out after that.
The globe is always on and it dims when the headlights are on.
I'd gladly sell you mine for $200 on an exchange basis It has a working globe.
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
NZ is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2006, 09:20 PM   #8
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Ha Ha Me too
I was lazy and got my fate to fix mine - in out in 20 minutes and thats with having a drink or two
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Originally Posted by rednose View Post
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2006, 05:04 PM   #9
MrEL
Sick Puppy
MrEL's Avatar
So all it is when the display is totally blank but everything else is working ok is a blown globe? I didnt realise a LCD display would have a globe in it!
MrEL is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2006, 07:37 PM   #10
Sorted
Sorted's Avatar
Yep thats right - just a globe. If the globe has blown you can still see whats on the LCD Screen its just very hard to see - look closely
Tuned by DYNOMOTIVE
Old 30-08-2006, 08:01 PM   #11
Junkz0r
Junkz0r's Avatar
Heheheh. LCD's don't illuminate themselves, they need some form of back-light so you can see the contrast between active and dormant segments. Old-school use a simple light bulb or LED, but these days they use fancy electro-luminecense panels behind the whole display for crystal clear clarity (no pun intended)
Junkz0r is offline   Reply With Quote Multi-Quote with this Post
