Old 23-08-2006, 08:23 PM   #1
matchstick xg
dropped
Default el fairmont bonnet on xh ute
is it possible to put an el fairmont bonnet and grill on a xh ute? what would needed to be changed in order to get the bonnet to fit properly
matchstick xg is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2006, 08:25 PM   #2
efgiar
rofl copter
efgiar's Avatar
u need to change the headlights and front bar
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2006, 08:28 PM   #3
Psycho Chicken
Psycho Chicken's Avatar
I'm pretty sure it won't fit cos of the radiator support height.
Psycho Chicken is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2006, 08:29 PM   #4
The Goodz
E-Series Firemaker
The Goodz's Avatar
You can't do it, they're a different length, and the shape of the bonnet at the windscreen end is still the same as an XD.
Alex
Automotive photography, fine art landscapes, portraiture
Photo retouching and restoration
The Goodz is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2006, 08:29 PM   #5
Psycho Chicken
And that.
Old 23-08-2006, 08:57 PM   #6
matchstick xg
dropped
**** ey, oh well ford got lazy with the utes and pretty much just changed the engine to the 4.0i and updated looks
Old 23-08-2006, 08:59 PM   #7
EFFalcon
Last warning
EFFalcon's Avatar
yep, you're stuck with EF/EL XR or EF GLi front :P
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 23-08-2006, 08:59 PM   #8
matchstick xg
dropped
what if ya chopped and changed the bonnet a bit? do you reckon you could get it to fit?
Old 23-08-2006, 09:04 PM   #9
EFFalcon
Last warning
EFFalcon's Avatar
anything can be done with a welder and filler :P
would probably be easier to try and adapt a grill to the XH bonnet and put on fairmont headlights/bumper.
Old 24-08-2006, 12:18 PM   #10
apolloxbgt
cross breeder
apolloxbgt's Avatar
I've actually seen that done,it looked quite good.
apolloxbgt is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2006, 01:24 PM   #11
EFFalcon
Last warning
EFFalcon's Avatar
oh, the fairmont headlights won't follow the lines of the bonnet at the front, you'd need to modify that.
i've got pics of the differences in shapes if u want to see. (For the headlights)
Old 24-08-2006, 01:59 PM   #12
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
I was led to believe that the XH actually was the first ute that got the different windscreen rake and so the fairmont stuff would fit.
Im sure it is different to the XG
BENT_8 is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2006, 02:05 PM   #13
EFFalcon
Last warning
EFFalcon's Avatar
the top end of the XH bonnet is still WAY different to the EF one.
if the fairmont bonnet was going to fit, ford would have used the normal GLi bonnet on the XH and not made a special bonnet for it.
Old 24-08-2006, 03:51 PM   #14
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
Ok, i just vaguely remember at the time, somebody, somewhere, mentioning that the windscreen had been changed for the XH to closer resemble the sedan..
I stand corrected!
Old 24-08-2006, 04:09 PM   #15
EFFalcon
Last warning
EFFalcon's Avatar
it may have changed, don't get me wrong.
how ever i don't think they're interchangable.
Old 24-08-2006, 09:59 PM   #16
apolloxbgt
cross breeder
apolloxbgt's Avatar
I stand corrected!
The only thing that was changed behind the subframe was the turret skin,the xd-g's had a square edged roof where the xh had rounded edges.
Old 24-08-2006, 10:08 PM   #17
LUXO_8
windsor user
even that was only a screw on trim at the end of the roof.... i bought one but never fitted it to my XF ute.
as mentioned best bet with the bonnet would be to fit fairmont headlights and try and tack on the front edge of the bonnet where it butts up to the lights to your existing bonnet....
Old 25-08-2006, 12:55 PM   #18
apolloxbgt
cross breeder
apolloxbgt's Avatar
It wouldn't have fitted,because as I said XH's have a different turret skin,ie it has rounded edges on the roof skin itself.
Old 30-08-2006, 08:09 PM   #19
matchstick xg
dropped
thanks guys but it sounds like its too much stuffin around for me
