Old 17-09-2006, 07:45 PM   #31
xbgs351
$2/litre is still cheaper and less hassle than replacing a blown head gasket from the inconsistent, rapidly evaporating 98 Octane pump fuel.
xbgs351 is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 08:04 PM   #32
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
Only ten short years ago I used to drive out onto the tarmac at Bathurst airport and fill my XT from the bowser. Dont think I would be able to do that anymore.
Just a few.
TURBOTAXI is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 08:32 PM   #33
flappist
Not a problem. All you need is an ASIC, an airside driving permit, $10,000,000 insurance, a "genuine reason" and a LOT of time to waste while waiting for the various government peasants to get around to processing your paperwork.
/sarcasm
flappist is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 08:37 PM   #34
MO
MO's Avatar
ASIC.. had one of them for 30 odd years....very handy.
FORD RULES OK
The more I know ppl the more I love my DOGS.
2011 SY Territory Limited Edition TS
2000 AUII SE ute IL6
MO is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 09:51 PM   #35
blakeyboy
avgas is being phased out due to the lead..
you can get limited quanitites if your racing category still allows it .. not for much longer...
you can actually make more power on PULP depending on your setup..
may be the right time to change over.. normally the issue is valve seats.
blakeyboy is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 10:02 PM   #36
protd
TUFF FORDS
protd's Avatar
normaly the issue is compression most people build there motors these days with hardened seat bronze valve guide and s/s valves anyway
protd is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 11:01 PM   #37
flappist
AVGAS will never be phased out. Despite all the screaming and whinging by the greenies neither lycoming nor continental will certifiy their engines for new fuels. Due to this any aircraft that are piston driven will be uninsurable if leaded avgas is not used.
Banning leaded AVGAS will ground almost all of the of the GA fleet in Australia instantly.
Old 17-09-2006, 11:18 PM   #38
Abacus
Life's a Gas
Abacus's Avatar
What he said.
Abacus is offline   Reply With Quote Multi-Quote with this Post
Old 18-09-2006, 07:17 AM   #39
Trevor 57
Trevor 57's Avatar
I'll second that.
Trevor 57 is offline   Reply With Quote Multi-Quote with this Post
