using a surround sound setup..
have the audio (via optical cable) going from dvd to it (surround system) but have video (vis s-video) cable from dvd straight to tv.. and the sound is out by approx 1 sec so do i pipe the s-video cable into the surround sound, and out to the tv? Where am I going wrong ???? Thanks in advance
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
Right out sideways
it shouldnt be out by a second, i have mine connected the same way.
is your digital out going into a reciever ? or just a surround decoder ?
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302 |
how long is the s-video cable?
i personally just use high quality (staff discounted) RCA cables (yellow red and white)
My Cars: 2002 Ford Falcon AU S3 SR 2006 BF MKI Falcon XR6 2008 Mazda BT50 SDX 2004 BA XR8 ute 2006 AUDI A4 B7 2013 FG II XR6 Ute 2006 Ford Territory TX 2003 Ford Falcon XR8 2009 Territory Turbo Ghia Current: 2012 Audi A4 B8 2.0T Quattro |
Fantastic Plastic
By right, the way you have it setup should be fine. I have mine setup with the coax for sound and the s-video for the pic and there is no delay.
It almost sounds like your dvd player isn't up to specs to run coax sound and s-video picture ( even though it has the outputs ! , heaps of crap dvd players out there like this ). Maybe try go into your menu on your dvd player / into the options / and set the sound quality at a lower setting, so the dvd player can decode both the picture and sound no worries . Also make sure the Audio in the dvd players menu is setup to direct the sound to the coax ! . Some players you can plug in the coax / not change any settings / and it works / but incorrectly usually. If your audio is set to AC3 (in the dvd player menu), then try changing it to PCM , this might also help .
Banana
Check the settings on your surround system through the audio menu. Mine has delay settings for each speaker depending on how far away they are from the screen. This may be part (or all) of the problem
2024 Ford Ranger Wildtrak V6 w/PP 2012 WK2 Jeep Grand Cherokee Overland CRD |
#6 | |||
PM me if you want
Failing that, plug it direct as possible and then test, KISS principle when testing things.
#7 | |||
not all on-board video switchers are created equally, and on poorer quality units, you might experience a lack of synchronization, and perhaps a noticable loss of quality on the video signal. If this is the case, the only thing you can do is bypass it, straight in to the TV as you have done.
