Old 30-05-2012, 05:35 PM   #31
svo supporter
Fixing Ford's **** ups
svo supporter's Avatar
Default Re: Painted wall Tyres Legal?
Originally Posted by Nikked
Nope...you didn't read the thread did you.
Putting a white wall on a tyre after it's manufacturered is ILLEGAL. If the tyre was manufacturered with a white wall, it's LEGAL. Simple
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises.
Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here
Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone
Old 30-05-2012, 06:07 PM   #32
Nikked
Oo\===/oO
Nikked's Avatar
no no no no no no...
-Painting a stripe on your tire, ie white walls IS NOT illegal
-Grinding out the tire for white walls IS illegal.
And this is why:
When a white wall is applied, the sidewall is ground back, so the surface is flat, so that the tire brand, load rating etc is all flat (aesthetically looks better) and It also helps adhesion.
Because the sidewall is altered, with the loadrating taken off, and the fact that some whitewalling people grind deep into the sidewall renders them illegal.
There are a few tires (i think kumho brand) that have a little band around the tire that doesn't contain any load rating information. With these tires, you can get away with painting a thin sidewall without rendering the tire illegal.
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2012, 10:16 PM   #33
Gspec ZL
Above is correct.
Paiting on a white wall although legal is a waste of time just doesnt last.
Grandpa's Tuff ZLane.
2000 AU Falcon Futura
78 Datto 200B granny spec
85 Merc 560SEL
Gspec ZL is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2012, 08:57 AM   #34
Honro
you CAN paint your tyre to get the white wall effect and it is legal as long as
- The load ratings are NOT covered / altered etc and the wall is not cut into.
Well thats what it is in the ACT. But the police will only enforce it if your being a dick really :/
Honro is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2012, 10:55 AM   #35
2011G6E
2011G6E's Avatar
I saw one where they seemed to cut a wide "groove" around the tyre on the sidewall...that kind of made my eyes bulge...wouldn't that weaken the hell out of your tyre?
2011G6E is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2012, 05:51 PM   #36
svo supporter
Yup, that's why it's illegal to do that.
