29-05-2012, 06:37 PM | #1 | ||
I have been speaking to a couple people about getting my tyre walls painted.
I have been told that doing this, the tyre is not roadworthy, due to the process of adding the paint to the tyre. I was told they shave the side wall of then tyre. Can anyone tell me if getting your tyre walls done makes the tyre unroadworthy? |
29-05-2012, 06:39 PM | #2 | ||
why would you want to????????????????????
clevo mafia (sadly sold) 351c xe manual (now with short shifting 5sp goodness) xc gs coupe project...hmm more clevo for me new daily 2005 ba sr |
29-05-2012, 06:43 PM | #3 | |||
Oo\===/oO
Yes...the side wall is ground away when walling a tire, so that the surface is even. They will defect you as the tire is "damaged" (not road worthy) and the load ratings are ground off. But, like all things car related, don't be a dick and you wont get attention. There is tires that are more suited to walling aswell.
Last edited by Pinkbits; 30-05-2012 at 08:01 PM. Reason: How about we refrain from name calling? |
29-05-2012, 06:43 PM | #4 | ||
Fixing Ford's **** ups
Rule is, any damage/cutting to the sidewall deems the tyre unroadworthy.
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises. Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone |
29-05-2012, 07:12 PM | #5 | ||
Ute Forum Moderator
On the other hand if there is a suitable space that allows painting without grinding away rubber, there would be no issue?
29-05-2012, 07:28 PM | #6 | |||
Oo\===/oO
Nope...all fine then. Just a light scuff to help paint adhere then.
29-05-2012, 07:38 PM | #7 | ||
You can buy them made that way in thin whites and wide whites no need to have them shaved
Or you can buy kits to paint them your self no shaving so it's not a problem
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
29-05-2012, 07:57 PM | #8 | |||
Oo\===/oO
The problem is, some/most tires have alot of writing, logos or designs on them, and the walls look better on a flat surface. There is one option, you could go rim skins...
29-05-2012, 08:29 PM | #9 | ||
buickman
29-05-2012, 08:34 PM | #10 | |||
N/A BOSS 390+
WOOOOOOOOOO FPV GT 03 /341 RWKW OF N/A POWER. XB GT 73 /OLD FORD MUSCLE ALL AUSSIE MUSCLE |
29-05-2012, 08:41 PM | #11 | |||
Chasing a FORD project!
First I'd heard of white walls being illegal. Like it would stop me though...
1996 BMW 740iL V8. TV, phone, leather, sunroof, satnav, all as standard. Now with 19" TSW Brooklands, 2 1/2" stainless steel exhaust, plus more coming soon. |
29-05-2012, 08:44 PM | #12 | |||
Oo\===/oO
Keep in mind they are not directly illegal but the methods used to apply them render the tire illegal. You can buy wide whites, narrow whites, and GT style red walls that don't break the rules...
29-05-2012, 08:48 PM | #13 | ||
Port a walls are also an option
29-05-2012, 08:50 PM | #14 | ||
if the walls are cast with the tyre during the manufacturing process, this is LEGAL.
if the walls are painted on with the sidewall being etched, shaved, ground etc whether or not the load ratings have been ground off, this is ILLEGAL. painting walls on without damaging the sidewall (just using some wax and grease remover to clean the surface), this is LEGAL. |
29-05-2012, 08:53 PM | #15 | |||
N/A BOSS 390+
29-05-2012, 09:03 PM | #16 | ||
29-05-2012, 09:03 PM | #17 | ||
Oo\===/oO
29-05-2012, 09:04 PM | #18 | ||
I'm old and I fell
One of the local Commodore heroes near my place has a good method of doing it. Grab yourself a can of white export and paint a ring-like line around the rim, being careful to paint the edge of your rim as you go, as well as not maintaining a hard outside line.
No shavings, no lost tire sizes or load ratings, just a white ring like line around your tire and some of your rim. Also cheap.
BF2 XR6 turbo 82lb injectors, Walbro fuel pump, bigger cooler, Plazmaman piping, SS Growler, tune, ZF tune, Crow valve springs so far. Ozracing coilovers, Pedders sway bars front and rear. 315rwkw |
29-05-2012, 09:06 PM | #19 | |||
Thailand Specials
29-05-2012, 09:52 PM | #20 | ||
john cains in newcastel does the muscle car thin walls in red etc
29-05-2012, 10:37 PM | #21 | ||
29-05-2012, 10:39 PM | #22 | ||
Lately i have done a lot of research on this subject. I live just near antique tyres as well. They really only do narrow sizes for legal white walls so if you want a narrow tyre your set. But i needed something for my datsun which has wide rims. I got flappers AKA port a walls. They are stressfull as you live in constant fear you will damage them. But they are an easy alternative. You can also buy them so they look like narrow white walls. The really arent as great as i hoped.
But if you really want white walls my advice is for cost and legality get flappers.
Grandpa's Tuff ZLane. 2000 AU Falcon Futura 78 Datto 200B granny spec 85 Merc 560SEL |
29-05-2012, 10:40 PM | #23 | ||
Oo\===/oO
I like standing back and looking at my car after i use tire foam...
29-05-2012, 11:54 PM | #24 | ||
Factory made white wall tyres are starting to come back into fashion, especially in the 14" range. A quick trip or phone call to your local tyre store is all you need to find out what is available....
Flappers are another good alternative.....Only problem is, they flap round in the breeze....hence the name....So good suggestion GSPECZL Just to clarify rules about white walls....If the factory manufacturers the tyre with a white wall, it LEGAL......If it's put on after the tyre has been manufactured, it's ILLEGAL
30-05-2012, 06:21 AM | #25 | ||
Cowboy
Take the deed to your house if you're planning a trip to antique tyre, should almost buy you a set of tyres there.
1927 Pontiac tourer 1928 Pontiac tourer 1929 Pontiac sedan 1930 Pontiac Landaulet 1932 Pontiac V8 sedan 1935 Pontiac sedan 1937 Pontiac 8 sedan 1948 Pontiac silver streak 1949 Ford F3 pickup 1953 Pontiac Chieftain 1955 Austin Champ 1957 Dodge Power Wagon 1967 Jeep Gladiator 1975 TD Cortina 1978 F100 4x4 2006 GU Patrol ute |
30-05-2012, 11:26 AM | #26 | ||
Thanks every heaps of good advise. If I was going to do it, Would try and get tyres that came out like that.
30-05-2012, 01:29 PM | #27 | ||
the prices I got for some odd sizes the other day wasnt obseen I didnt think cowboy
30-05-2012, 05:20 PM | #28 | ||
There prices are probably not obscene but they are also not cheap. I like the guys there but when i ordered some chrome hubbies about 3 months back and they took until last week to arrive i wasnt pleased. i should have just got them online. But no not cowboy for sure.
I hope SVO Supporter that you a right because i cound find nothing for my 14 inch rims at all. beacause they a 7inch width nothing came close. I did a fairly comprehensive ring around and net search but prehaps popularity is climbing.
30-05-2012, 05:38 PM | #29 | |||
Oo\===/oO
30-05-2012, 05:47 PM | #30 | |||
Cowboy
