08-06-2005, 06:23 PM | #31 | ||
Last warning
plumbed up or blown up?
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
08-06-2005, 06:28 PM | #32 | ||
V8 Turbo Hoon
plumbed up, bit worried about that flexi vn v6 coupler. it might balloon out.
08-06-2005, 06:30 PM | #33 | ||
Last warning
should be ok...
driven it yet?
08-06-2005, 06:33 PM | #34 | ||
V8 Turbo Hoon
nah just finished it, im having dinner now, ill go out later and see how it goes! actually maybe after neighbours lol
08-06-2005, 06:34 PM | #35 | ||
XRSVO
making heaps of progress mate ,Ive got some old silicon couplings off my setup I can donate if you need
08-06-2005, 06:59 PM | #36 | ||
V8 Turbo Hoon
i need a tune bad now, its next to undriveable with the turbo connected! hopefully by this weekend too.
08-06-2005, 07:54 PM | #37 | ||
NO CARBON TAX
good work buddy, but wheres the turbo?? lol
disconnect the exhaust when you have turbo plumbed then listen to it whistle. mine sounds like a doorslammer with the whistle of a massive blower. cant wait to change exhaust to 4 inch, hope it meets andra db limit
THE WORLDS FASTEST BISCANYE BLUE EB FALCON WITH EB BLOCK AND HEAD!!! NO AU **** THANKS Atomic performance engine, powerglide, coan converter, gtx55 turbo, 2000hp plazmaman water to air, 100mm throttle body, twin 50mm gates, side exit exhausts, 18 x 2200cc injectors, ems 8860 and race dash....... 7.83 @ 177 MPH 1100+ rwhp @ 40psi the first 7 second sohc ! eat it 1993 eb falcon 15.4 @ 90mph (tow car) |
08-06-2005, 09:16 PM | #38 | ||
V8 Turbo Hoon
i hope it will be drivable with the turbo connected by sunday, ill have a balance line tommorrow hopefully and air filter, a sock over the pipe is really restrictive and makes it run rich as buggery.
08-06-2005, 09:18 PM | #39 | ||
Last warning
so its TOO rich atm?
the balance line should help out i imagine. still going siwft for the intial tune?
08-06-2005, 09:22 PM | #40 | ||
V8 Turbo Hoon
yeah going to swift, donw know anyone else nearby who know much about gas and forced induction/performance.
either really rich or really lean or no fuel, as soon as the turbo came up even at 1500 it just dies. Last edited by Qwikcorty; 08-06-2005 at 09:46 PM. |
10-06-2005, 06:54 PM | #41 | ||
V8 Turbo Hoon
vvvvvssssshhhhhhh du du du du :
10-06-2005, 07:04 PM | #42 | ||
XRSVO
im guess'n you got a tune ,how is it?????????
10-06-2005, 07:17 PM | #43 | ||
V8 Turbo Hoon
goes good, clutch dont like it though
10-06-2005, 07:31 PM | #44 | ||
windsor user
awesome matt....
sounds like fun hows that VN flex going? |
10-06-2005, 09:24 PM | #45 | ||
that flex hose will be fine. hows it run?
10-06-2005, 09:36 PM | #46 | ||
Last warning
the VN flex split :P
he replaced it with a silicone hose.
10-06-2005, 09:39 PM | #47 | ||
Hmm holden build quality is questionable. Should have got one from a XF ;)
10-06-2005, 09:47 PM | #48 | ||
windsor user
haha! didnt think it'd last long...
10-06-2005, 09:48 PM | #49 | ||
V8 Turbo Hoon
i need a stronger throttle return spring,
sometimes i lift off and shes still pulling hard for 1-2 seconds!! yeah vn pipe thingie split down middle made loud pop noise! |
13-06-2005, 08:22 PM | #50 | ||
Turbo Falcon Fiend
Yeah the balance line will be really important.
I have been messing with my angle and length for a better power delivery. I am getting closer to a better result. Do you have the intercooler on now? What sort of power do you think you are getting (hopefully better that 135 rwkw) Roy |
13-06-2005, 08:25 PM | #51 | ||
Last warning
Turbotaxi: he was already pushing about 141rwkw when the car was on petrol.
the conversion to LPG and the turbo should deffinately see quite an improvement, and you can feel the pickup in the car big time.
13-06-2005, 08:28 PM | #52 | ||
V8 Turbo Hoon
feels like it has twice the torque at 3000rpm! it will just GO in any gear. dont know what power it would have i just love the midrange!
hmm power, maybe 160-200rwkw ? i have no idea and wont find out when till its tuned, but that wont happen till i have a new decent clutch that holds it. Last edited by Qwikcorty; 13-06-2005 at 08:34 PM. |
13-06-2005, 08:31 PM | #53 | ||
V8 Turbo Hoon
turbotaxi: my feed for the balance line goes like this>
13-06-2005, 08:47 PM | #54 | ||
Turbo Falcon Fiend
That look great!. mine is just cut at 45 and angled into the airflow (in an attempt to scoop it) as per advice from this forum. However I am still using the Landi Renzo convertor and 50mm mixer ring with no cooler.
I am really excited for you, and can see from your posts that you are rapt, wish I had the same result! I will get there, but in the meantime I will look forward to reading about your setup. |
13-06-2005, 08:55 PM | #55 | ||
Last warning
got any pics of the balance pipe matt?
i'm gunna have to work out where i can put mine :/ i guess u'd put it close to the t/b?
13-06-2005, 09:03 PM | #56 | ||
V8 Turbo Hoon
as close to the turbo as possible , i got mine in the 90 degree bend straight out of the turbo, then i guess the boosted air gets to the convertors quicker than the throttle as the lines are smaller diameter.
And the result is no flat spot what so ever from vacumm to boost. just a good kick in the back! |
13-06-2005, 09:11 PM | #57 | ||
Last warning
ah nice, i don't mind hacking up that section of my cooler piping, its not chrome :P
14-06-2005, 05:17 PM | #58 | |||
X-Series Club Moderator
Looks damn good Matt. Are you going to race it a Heathcote? |
14-06-2005, 05:34 PM | #59 | ||
V8 Turbo Hoon
whens the next heathcote meet?
14-06-2005, 05:35 PM | #60 | ||
Last warning
Fordforums one in July
E-Series vs R31 Skyline one in august.
