Old 10-06-2007, 08:39 PM   #1
ea ba turbo
chasing more power
ea ba turbo's Avatar
Default I6 head studs
Just wondering if anybody is interested in head stud kits for their 6cyl
I have 3 sets coming with ARP 12point nuts & washers.
The cost would be $350 a set.
These studs have been tested in a few applications now and have passed with flying colors.
If you are interested please pm me and i will get back to you as soon as possible.
9.93@140.8mph......more to come
Thanks to Mikes Dynos
ALLRACE & K.E.A.S.
ea ba turbo is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2007, 11:10 PM   #2
Rollin
Rollin's Avatar
Are they re-usable or do you have to get new ones every time the head comes off?
DO you think they would be worthwhile for a motor that's been properly machined, has an O-ringed deck and copper head gasket?
Rollin is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2007, 12:25 AM   #3
ea ba turbo
chasing more power
the studs can be used a number of times.....
Would greatly improve the whole package...no point having all that done only to stretch std bolts and risk damage.
ALLRACE & K.E.A.S.
Old 11-06-2007, 07:20 PM   #4
EFFalcon
Last warning
EFFalcon's Avatar
how is it geting the head on at the back with these?
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 11-06-2007, 08:24 PM   #5
fritzz
fritzz's Avatar
the only way its possible to get the head off with studs is if the studs have an Alan key hole in the top to screw them out.
studs are fully re-usable, they are a good idea in a engine that running 25-30psi+.
but ive never seen any trouble with normal bolts.
6boost was running 32psi in his and it was still on stock bolts for a long time never had any trouble.
# 1997 EL Falcon GLI - Custom built AU 4L bottom end, Billet Turbos B76-GTS, Nizpro plenum, 6boost manifold, Autronic SM4, Custom billet surecam camshaft, 3x 044 pumps and custom undercar surge tank, Custom 4" exhaust, ID2000 Injectors, 60mm Turbosmart gate, Turbosmart race port bov, , Tremec TKO 600, Cebco 330mm Brakes, 3.7:1 9" diff with billet axles and trutrack center 608rwkw, 9.6sec 1/4mile
# 2008 FPV FG GTE - Xa Coilovers, 20x8.5/ 20x10 fairladys
fritzz is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2007, 09:46 PM   #6
ea ba turbo
chasing more power
studs can be fitted or removed with the head in place....
fritzz is correct that you cant get the head on & off with studs in place.
have seen heads lift with std bolts with as little as 15psi boost
ALLRACE & K.E.A.S.
Old 13-06-2007, 12:22 AM   #7
Rollin
Rollin's Avatar
What time frame are you looking at needing an order in?
Old 14-06-2007, 12:44 AM   #8
ea ba turbo
chasing more power
just let me know, whatever suits...
waiting on nuts now, then i will have 3 sets in stock.
once there gone only a week or two to get more sent
ALLRACE & K.E.A.S.
Old 14-06-2007, 07:46 AM   #9
EF_Frmnt
EF_Frmnt's Avatar
i wouldnt mind these, fair few dollars but im sure its worth it for a top level motor. Ive also got a big thick ***** off copper gasket sitting here, and its not a good idea to retain standard bolts because of the added thickness, means fewer threads are properly seated. I just have to wait for my au block to arrive so i can get that O-ringed and away i go.
EF_Frmnt is offline   Reply With Quote Multi-Quote with this Post
