Old 14-06-2007, 04:32 PM   #1
ILLaViTaR
ILLaViTaR's Avatar
Default Using a digital multimeter
I borrowed a multimeter from my school and was wondering how to use it.
Since my car is running like crap I need to check the TFI and a lot of other things apparantly.
The thing that confuses me is the dial on it there's tonnes of different options
like for ohms you got 200k, 20k, 2k, 200, same with everything else.
I'm checking the leads now and picked 20k and it came up as 7.97 on the multimeter which is really weird cause that's around 10k below spec
ILLaViTaR is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2007, 05:25 PM   #2
efgiar
rofl copter
efgiar's Avatar
the ohms reading for leads depends on the brand and what kind of leads they are, 8kohms isnt a bad reading, if the ones of similar length are all around that reading then it will be fine, its the ones that are open circuit or read too high that give you grief.
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2007, 08:22 PM   #3
accurate1
7.97 equals 7,970 ohms or 7.97Kohms so the leads are OK.
accurate1 is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2007, 09:02 PM   #4
94EDxr6
5.SPEED
94EDxr6's Avatar
what resistance are you looking for in ohms? If you're testing your leads they should have very little resistance. I'm not a mechanic but it would have to be below 0 ohms. Put the setting on 200. Whatever comes up then will be your resistance.
94EDxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2007, 09:06 PM   #5
sphell
sphell's Avatar
And I'm no rocket scientist but how is that possible? :togo:
Old 14-06-2007, 10:20 PM   #6
needfordspeed
It's a streamlined butterfly, no resistance what so ever!
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH
needfordspeed is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2007, 10:30 PM   #7
No; most modern leads do have resistance (to suppress radio noise) and carbon ones are typically as high as 40K ohms. If you had old fashioned noisy copper wire core lead you might get reading less than 10 ohms. Ford ones should have a max resistance of 21 K ohms and 7 k ohms is right on for new leads.
Old 14-06-2007, 10:31 PM   #8
ILLaViTaR
ILLaViTaR's Avatar
Yeah leads look fine.
How do I check the TFI module with a multimeter?
Do I have to disconnect the negative battery terminal?
I done that and probed pin 4 and 5 and nothing happened.
My cars been running like crap for a week. Also found out that the transmission is leaking oil and it was only serviced 20 000k's ago. It's leaking form the oil pan so it's just a retightening I think.
Old 14-06-2007, 10:34 PM   #9
see http://www.therangerstation.com/tech...iagnostic.html you need to remove the module to test it.
Old 14-06-2007, 10:49 PM   #10
ILLaViTaR
ILLaViTaR's Avatar
hmmm.
How do I check for spark in the spark plugs?
My problem is the engine idles low and runs rough (like when it's misfiring but I got the firing order correct).
Old 14-06-2007, 10:55 PM   #11
To test the leads are supplying spark remove fuel pump relay and get a good used spark plug open the gap up to about 3mm and put in each lead in turn allowing the plug to ground against the engine head or block and watch for a spark. To test plugs remove each plug in turn and do the same thing (but leave gap at specifications).
Old 14-06-2007, 10:56 PM   #12
Also check air or fuel filter is not clogged - both will give the symptoms you describe.
Old 14-06-2007, 11:00 PM   #13
accurate1
[QUOTE=ILLaViTaR]
If the car is running why do you want to check the TFI module?
Old 14-06-2007, 11:07 PM   #14
ILLaViTaR
ILLaViTaR's Avatar
I was told to check it. So since it's running I'm guessing the coil, distributer and TFI are fine??? (excluding ignition timing since I hacn't checked it yet).
I took the air filter out and ran it for around 20 seconds and same problem.
I'll also mention that when I put the leads back on ever since then when I start it the crank sounds extremely weak and unsmooth.
Im very happy it doesn't sound mechanicallly related. (I've checked timing chain and it's fine and rocker gear seems fine by the looks of it).
Old 14-06-2007, 11:11 PM   #15
Is the distributor cap sitting tight and in locating notch? Is king lead (central HTlead) still in coil at coil end?
Old 14-06-2007, 11:13 PM   #16
Check there is no corrosion in distributor cap where leads plug in and all leads are pushed right down on the spark plugs (I guess you didn't use the right lead removal tool to pull the leads of the plugs and didn't put dielectric paste on each end of the leads when plugging them in again - if so you might fine a lead had moved up the HT lead's plug boot so it cannot clip fully onto the spark plug).
A tool like this:
Old 14-06-2007, 11:14 PM   #17
ILLaViTaR
ILLaViTaR's Avatar
Coil lead is in both ends.
unsure about distributer I'll have to check it out tomorrow.
I don't think I've ever touched it until now.
It's been happening ever since I changed the thermostat which makes no sense.
I ran it for around an hour in total with the new thermostat idling and the next day I started the car to find this problem
Old 14-06-2007, 11:21 PM   #18
Did you follow the air bleed procedure after replacing the T stat? No chance you put the T Stat in upside down is there?
More likely you spilt coolant into the TFI module plug and socket at the distributor end as it's under the T Stat. Unplug TFI plug and after drying out with WD 40 or CRC fill socket with thermal paste per factory manual specs (Unick from Altronics. Jaycar or Dick Smiths is cheaper than the Ford supplied stuff).
Old 14-06-2007, 11:23 PM   #19
Old 14-06-2007, 11:26 PM   #20
ILLaViTaR
ILLaViTaR's Avatar
Hmmm what was the air bleed procedure again?
It might've spilt whilst the thermostat was out when flushing (water was leaking out due to no seal).
Also there's no way I put it in upside down.
Old 14-06-2007, 11:37 PM   #21
I told you here; http://www.fordforums.com.au/showthr...ight=air+bleed
Old 14-06-2007, 11:38 PM   #22
I would pull the plug that goes into the TFI module and see if there is any coolant in there and if there is a liberal amount of thermal grease (white goo) in the socket. 5 min job.
Old 14-06-2007, 11:46 PM   #23
ILLaViTaR
ILLaViTaR's Avatar
Oops sorry I ddn't do all of that correctly.
I put in the thermostat and then filled it up.
So it's probably got an air lock, I'll drain it all, and refill it properly.
I just realised how *** stupid that was, Since I drained it there was probably no water in the block and when it sensed the air being hot in the block it mustive released the water into the head, it was rather warm before it went in though but hopefully I havn't blown a bloody head gasket.
Would a blown head gasket or worse a cracked cylinder head explain the symptoms that I'm having?
I aint getting white smoke though
Old 14-06-2007, 11:56 PM   #24
Lets pray it's an air lock.
Old 15-06-2007, 12:02 AM   #25
ILLaViTaR
ILLaViTaR's Avatar
Yeah, I don't see any coolant dripping form the head gasket although it is extremely hard to see the gasket itself.
There's no way to be sure if it's the gasket unless I actually take the cylinder head off is there?
Man taking the rocker gear, and manifolds off is gonna be an extremely frustrating job.
Old 15-06-2007, 12:07 AM   #26
ILLaViTaR
ILLaViTaR's Avatar
This also explains why it took 1/2 an hour for the thermostat to open... ****.
Could have this screwed up the whole engine form overheating???
I'm trying to think worst case scenario.
Headgasket shouldn't cost me to much if I do it myself, I'm thinking if I screwed the whole cylinder head or worse the whole crankshaft part form overheating.
Old 15-06-2007, 12:10 AM   #27
You should be Ok provided it hasn't overheated too much since. The air lock usually doesn't blow a head gasket for some time esp in winter.
Old 15-06-2007, 12:12 AM   #28
More likely coolant in the TFI connector socket.
Old 15-06-2007, 12:24 AM   #29
ILLaViTaR
ILLaViTaR's Avatar
Hmmm yeah.
It's not the fact of an air lock I think. It's the fact that I filled it up from the surge tank and not the thermal housing. The thermostat would not open till 91 degrees yeah?
Meaning that the thermostat was blocking all the water from the head. The head being empty (since I drained flushing liquid from it). The air in the empty head would have heated up to 91 degrees and opened the thermostat letting only warm water into the extremely hot head damaging it.
Also water absorbs heat and air doesn't so the engine would have been extremely hot when it let water in?
Old 15-06-2007, 12:27 AM   #30
Lots have people have got away with doing this and it is usually only the overheating from the air lock that eventually creates a problem with a blown head gasket. Don't worry unduly yet and just go through the air bleed coolant filling process before it is too late.
If the T Stat had a Jiggle pin a (best) or bleed notch (not as good) some coolant will enter through that and more through lower raditor hose (mostly there) as some air will bleed through the jiggle pin or bleed notch and let coolant enter fromm below. However the bleed notch and jiggle pin bleed much too slowly to let all the air out and some will be still trapped in the engine block and mainly in the head. Remove T stat housing and T stat and start correct filling and air bleeding procedure again to fix it.
