Old 23-05-2005, 10:53 PM   #1
InitialD
Low and Loud
InitialD's Avatar
Default Battery Gunk
While checking the fluids of the EA today, I noticed that my batter had excessive amounts of battery acid that had leaked from the caps and had "caked" around the caps. Is this normal?
Ive never had this on my cars before. I checked the levels and it needed a small amount of distilled water added. The battery is charging at a normal 14.7volt. The battery is a 460CCA btw ;) and is about 1yr old
Old 23-05-2005, 10:58 PM   #2
Psycho Chicken
Psycho Chicken's Avatar
Errrr around the caps, that's not normal. They on good and tight? It forming on the terminals?
Old 23-05-2005, 10:59 PM   #3
InitialD
Low and Loud
InitialD's Avatar
They are good and tight, Terminals are clean, No crap on them at all...
This is why i was concerned
Old 24-05-2005, 01:03 AM   #4
RED_EL_XR8
RED_EL_XR8's Avatar
Over-charging a tad, most likely, put a meter on it.
RED_EL_XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2005, 01:18 AM   #5
InitialD
Low and Loud
InitialD's Avatar
Im running a Mitsubishi 70amp Alternator from a EB, And ive put a meter on the battery when running and its 14.7
Old 24-05-2005, 01:20 AM   #6
Racecraft
they call me Tibbo
Racecraft's Avatar
14.7 is alittle high, probably causing some boiling after a while..
Old 24-05-2005, 01:22 AM   #7
InitialD
Low and Loud
InitialD's Avatar
14.7v is high? What should it be at? I allways thought it should vary between 14.2 and 14.7 is good
if its alittle high, i guess ill just drive around with the stereo cranked louder now ;)
Old 24-05-2005, 01:24 AM   #8
Psycho Chicken
Or put thermos on :P
Old 24-05-2005, 01:24 AM   #9
InitialD
Low and Loud
InitialD's Avatar
I like your thinking ;)
Old 24-05-2005, 08:02 AM   #10
ilsautomotive
Former E-Series Member
I didn't think modern cars overcharged. Thermos sound good. Maybe one of those intake cooler thingys that some guy on Fordmods did.
