Old 09-07-2007, 12:35 PM   #1
kocho
The Futuriser
kocho's Avatar
Default Fuel Consumption Calculator
Anyone know of a good online one?
I'm trying to work out how horrible my fuel consumption is.
I've travelled 362k's I know that.
Currently, my computer (on the BA that is) says that I'm doing 14.2 L/100KM which is really good (usually I'm at 15L/100KM). However, I want to work out just how accurate this is.
Also, I havent completely got an empty tank. Its fairly close, however this makes a big difference.
Thanks.
Current Subaru Liberty MY08 2.5 SatNav
Previous 2003 BA Ford Futura.
CKGD - Freelance Graphic Designer
kocho is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2007, 01:15 PM   #2
King Nothing
He has, the Knack..
King Nothing's Avatar
You don't *need* to completely empty the tank. It would be better if you could but can still do it without. When you fill the car, fill it completely so that you physically cannot get any more in. Then drive. I'll assume you have done this already.
Now go and fill the car up completely, and take note of how many litres it took. Then simply divide how many litres it took by how many km you travelled (362 in your case) and multiply by 100. At a guess you have probably used about 51 litres.
That is pretty much the only way to do it.
2010 BF MKIII Falcon wagon "EGO"
Workhorse, stock as a rock
2004 BA MKI Futura - Now the wife's
For Show: 18" Kaotic Shadow Chrome, King SL all round, Cadence Amp, Kenwood 12" Sub, JL Audio 5x7's, Scuff Plates, MP3 Connector
For Go: SVI LPG, K&N Filter, F6 CAI, XR6T snorkle, XR8 catback, Magnaflow metal cat, Pacemaker headers, Underdrive, Thermostat, Custom tune, DBA4000
Now with baby seat and toys
175.6 rwkw
www.bseries.com.au/King_Nothing
King Nothing is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2007, 01:22 PM   #3
flappist
Forget the car computer, it is not even remotely accurate most of the time.
Fill the car, note odometer reading.
Drive.
Fill car again, note odometer and bowser readings.
Take original odometer reading from current reading to derive distance travelled.
Divide litres used by distance travelled and multiply result by 100.
Final result is litres per 100km.
fuel usage (l/100km) = fuel used (l) / distance traveled (km) * 100.
(which is the same as the page above, who beat me to it)
Old 09-07-2007, 01:43 PM   #4
kocho
The Futuriser
kocho's Avatar
Ok, great, thanks guys!
Old 09-07-2007, 02:22 PM   #5
Kryton
Kryton's Avatar
http://www.accommodationz.co.nz/economycalculator.html
Kryton is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2007, 02:37 PM   #6
Unco
Unco's Avatar
or you could just fill up, then drive 100 km's and fill up again.
Unco is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2007, 02:46 PM   #7
Outbackjack
Central to all beach's
Outbackjack's Avatar
If you have access to a C++ complier you can compile this and run it from the DOS (c prompt....
I just wrote it, it is very basic, but accurate.
#include <iostream>
using namespace std;
int main()
// A programme to calculate fuel usage.
// create floating point variables
double litres, kilometers, factor, usage;
// request the amount of fuel used
cout << "Input litres used and press enter:";
// put fuel used into variable litres
cin >> litres;
// request the number of kilometres travelled
cout << "Input kilometers travelled:";
// put kilometers travelled into variable kilometers
cin >> kilometers;
//calculate the factor i.e kilometers travelled divided by 100
factor = (kilometers / 100);
// calulate litres used ie litres divided by factor.
usage = (litres / factor);
// output litres used per 100 kilometers
cout << "Litres used per 100 kilometers:" << usage;
return 0;
Cheers.
PS if you have a PDA you could also run it on that.
Real Aussie muscle cars have a clutch!!
http://www.roadsense.com.au/about.html
Outbackjack is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2007, 03:05 PM   #8
King Nothing
He has, the Knack..
#include <iostream>
int main()
cin >> litres;
cin >> kilometers;
return 0;
Cheers.
Sounds like you're working for your car.
SIMPLIFY, MAN!!
*If someone could PLEASE find a pic of that hippy guy from the simpsons, that would be fantastic!
175.6 rwkw
Old 09-07-2007, 03:08 PM   #9
Outbackjack
SIMPLIFY, MAN!!
It doesn't get any simpler (sp?) than that.....
Old 09-07-2007, 03:37 PM   #10
Rodp
Regular Schmuck
Rodp's Avatar
Thanks.
Is there something wrong with your car or do you have a heavy right foot? I routinely get 420-450k's out of a tank (usually using 91RON) in an XR8 in Sydney traffic. Last time I looked, I was doing 13.6L/100.
I use the method already described in that I fill the tank completely up and zero the odometer, that way it doesn't matter when you fill up next, you can get a reasonably accurate measurement based on how many L's it takes to fill the car right back up again vs how many k's you travelled since your last fill.
Old 09-07-2007, 03:43 PM   #11
King Nothing
He has, the Knack..
lol yeah I know, I was just commenting on how you went to the effort to write that. I think it's cool. It's just that a non-car nut might look at you like you have 3 heads if you told them you wrote that. Well the ones I know anyway. No offence intended mate.
EDIT: Woo! 351 posts! Such a cool number
175.6 rwkw
Old 09-07-2007, 03:46 PM   #12
Outbackjack
No probs.... Most of it is just comment fields, everything after // is just a comment.
I suppose I should test it, but I can see no resaon it shouldn't work. :
Old 09-07-2007, 06:06 PM   #13
kocho
The Futuriser
kocho's Avatar
I know theres something wrong with my car. Just that the stupid Ford people dont think theres anything wrong. The mechanic I went to thought similar aswell.
I'm thinking its the O2 sensor, so I might buy a new one just to see.
"I never get below 14L/100KMS around here (suburbia)" I said
"Ohhh... I wouldnt worry about that. That sounds about right" the guy at Ford told me.
I can tell that it cant be right. Barely anyone on here gets what I get in their I6 BA. I'm getting similar readings to that of an XR6T (probably just a fraction less).
Old 09-07-2007, 07:10 PM   #14
kocho
The Futuriser
kocho's Avatar
Ok, so I just filled up 55.32 litres into the car.
Having travelled 362km's I worked this out:
fuel usage (15.3l/100km) = fuel used (55.32l) / distance traveled (362km) * 100.
So, my BA's computer seems to be out by 1L/100km which makes things even WORSE!
AAAHHHH! :(
Old 09-07-2007, 08:31 PM   #15
TEaaron
TEaaron's Avatar
Oh sweet, used that calculator.
My 3.3L Xd gets 22L/100k's with half the power of a Ba w00t.
TE cortina 14.0 @ 101mph
E32 740iL Leather, sound system, rollin' on 19's
TEaaron is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2007, 08:34 PM   #16
holmsy
holmsy's Avatar
mine comes up roughly 13.5 litres per 100km.
with my driving which is flat to the floor constantly. in a 10 year older car.
thats not bad.
my trip computer how ever is over 100km's out on its distance till empty.
holmsy is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2007, 08:39 PM   #17
Unco
Unco's Avatar
is that with the new cam and 500 holley and flooring it everywhere? cause i get 21L/100Km from a 351 pulling a 1.8ton tank.
Old 09-07-2007, 08:42 PM   #18
Zoink
Zoink's Avatar
There is nothing wrong with your fuel consumption, it all depends on your driving style and conditions.
I drive a 2003 Futura daily to and from work in Sydney rush hour traffic.
This consists of 32sets of traffic lights, 14 roundabouts, 12 speed bumps, 2 give way signs, 2 stop signs and 50,70,90 and 40km/h speed zones all in the 30.4km distance for the round Trip.
My average fuel consumption is 17.9ltrs/100k at an average speed of 32km/h
Same car is used for interstate travel , Sydney to Cairns 3 or 4 times a year.
This returns on average 9.2ltrs/100k at an average speed of 92km/h
Best I ever got on one tank was 8.9ltr/100k at an average of 98km/h, this was at night, and it was cold.
(above consumption figures are calculated, the average speed is from the trip computer)
Zoink is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2007, 09:23 PM   #19
Silver Ghia
Silver Ghia's Avatar
Rodp gets full marks.
I do this everytime I get into the car after filling up, take note of the kms on the trip meter, then zero it.
When I get home I multiply the number of litres I just put into the tank by 100, then divide by how many km was on the trip meter. (Consumption = Litres*100/km).
That way you can monitor your fuel usage closely.
BTW. The BA has a good feature in that once the fuel nozzle goes click, the tank is full, unlike many other types of cars.
Silver Ghia is online now   Reply With Quote Multi-Quote with this Post
Old 09-07-2007, 09:26 PM   #20
King Nothing
He has, the Knack..
In my BA futura I average around 10.0-10.5, depending on what half of the week it is. I drive between sydney and wollongong for work, and do a bit of suburban driving on the weekends.
Before I was highway travelling I would get around 13.5-14L/100km around the suburbs, so your fuel consumption is a bit high but not excessively. Again as it has been said above it depends on your driving style. I found up to a 1L/100km difference if I really babied it. Try taking it for a run on the highway and see what sort of consumption you get, it should be around 10ish
175.6 rwkw
Old 09-07-2007, 09:49 PM   #21
kocho
The Futuriser
kocho's Avatar
I'm taking it tomorrow down the highway. I'll see how I go. I think last time I got around 10L/100KM.
Old 09-07-2007, 10:17 PM   #22
Rodp
Regular Schmuck
Rodp's Avatar
Geez. You must drive with a massively heavy foot. I'm reading 34km/h average speed and 13.6L/100km in an XR8!
Old 09-07-2007, 11:08 PM   #23
TEaaron
TEaaron's Avatar
Nope that's with a full standard cast iron 200 motor and Xf weber flooring the absolute **** through it.
I rev the motor to 5300-5500 because it simply won't rev harder and it's stock when ever me and my mates see somthing industructible we say... XDEEE
Old 09-07-2007, 11:14 PM   #24
Unco
Unco's Avatar
those webers are pretty thirsty when you got a lead foot. my 21L/100Km is around the suburbs with the occasional squirt. on the highway i get around 16L/100Km
Old 09-07-2007, 11:18 PM   #25
TEaaron
TEaaron's Avatar
I sit at 3200 in 4th on the highway.
Old 10-07-2007, 10:24 AM   #26
Kashmir Mafia
Kashmir Mafia
You could use this one. You just need to register to be able to use it
http://www.spritmonitor.de/en/
Kashmir Mafia is offline   Reply With Quote Multi-Quote with this Post
