i,
Im getting a single beep coming from the dash of my AU XR everytime i brake a little harder than normal and also when i take off from a standing start a little hard and go into 2nd gear loosing a little traction. Anyone have any ideas what this maybe ?? I did have to use the ABS a few days ago, which made the same beep noise? Any Help would be great. Regards 220kwxr8 |
It may sound funny, but check you wiper washer fluid level, early AUs beep when the water is low, and on take off and when braking the water may swish around enough for the sensor to think its empty
Have Boost, will use it..
Not trying to sound smart..... but my BA does that when I have the boot open. ie boot lid is down but not completley closed. Sudden movements in the rear cause the sensor to triger a short and single beep.
Go round the back and see if you can lift the boot lid. |
Thank you for the replies.
ill try the washer fluid thing cause that does sound logical. as for checking the boot thank you for the idea but i have a ute ![]() thanks your help has been great and i will keep you updated. Regards 220kwxr8 |
