Old 18-07-2007, 08:55 PM   #1
alanjwells
alanjwells's Avatar
Default Thermo v belt driven fan/s?
I did a little seach and could not find much information on this.
I am fitting a 302 Windsor to my XY falcon. Am thinking thermo fans instead of the traditional bel driven fan. I can see that there should be power gains from using thermos over belt driven fans just by the fact that the belt will cause, however little, a resistance.
Also if I were to do thermos it would be my thinking that dual fans are better than a single as if one fans fails at least the other one will still cool.
Anyone find a reason to talk me out of doing this?
Mine: XY Falcon 302w, C4 auto
Family: 2010 Territory Ghia
Work: Dual cab Hilux
alanjwells is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2007, 08:59 PM   #2
asusdragon
BA Falcon XT
asusdragon's Avatar
nope i would say go twin thermo, least if you sitting in traffic and your cars getting hot the thermo can speed up, belt cant do anything expect spin at the engine speed
and there got to be a bit more power of belt least pull on the crack
Click here to check out my signature
http://i238.photobucket.com/albums/f...ignature-1.jpg
If you can't fix it with a hammer. you're got an electrical problem
You only need two tools in life - WD40 and Duct Tape. If it doesn't move and should, use the WD40, If it shouldnt move and does, use the duct tape
asusdragon is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2007, 09:05 PM   #3
Whitey-AMG
AWD Assassin
Whitey-AMG's Avatar
Twin 12" thermos will / should give better results than a single 16".
Just make sure you "shroud" the units........like the current factory set up in the EL - BF series falcs. You need the shroud to get draw through from the entire rad surface.
Do not bolt them straight on to the rad as this reduces the "draw through" effect and will not yield the best results..........In fact, you may find that you will go backwards.
Bset bet is to pick up a set from the wreckers from an EL or BA. They are plentiful and work brilliantly.
If you but them as a single unit........e.g from Davies Craig etc.....they do not come with a shroud and you may not be entirely happy with the results.
Whitey-AMG is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2007, 09:06 PM   #4
BZINGA
Powered by Ford
BZINGA's Avatar
You would need to run a GT radiator or a X-Flow style to run AU thermo's, a standard windsor radiator will be to small for it.
BZINGA is offline   Reply With Quote Multi-Quote with this Post
