28-05-2005, 05:19 PM | #1 | ||
Shoot.
I've got an exhaust leak coming from the manifold so I am hoping the gasket is just shagged. So when I replace it, do I need to use exhaust sealant type stuff? Anything special involved when changing it?
20V Turbo |
28-05-2005, 08:23 PM | #2 | ||
After a number of blow outs of exhaust gaskets I now use some good quality silicon sealer instead of the gasket. Pacemaker, JMM and others recommend this and I haven't had a problem since.
28-05-2005, 09:00 PM | #3 | ||
RIP...
Yep, don't need a gasket, just silicon.
Rick.
. Oval Everywhere... |
29-05-2005, 07:17 PM | #4 | ||
OzECruisers Treasurer
I used new gaskets, no silicon, and it works fine.
29-05-2005, 07:37 PM | #5 | ||
likes falcon's
i only use metal gaskets, never had troubles?
www.carhubsales.com.au |
29-05-2005, 09:01 PM | #6 | ||
Custom user title
yes use.. EF/el/au style gaskets (ford ones)..... steel shim :> they carnt blow out... if they leak u simply tighten them up
