Old 28-05-2005, 06:58 PM   #1
Grechie
Grechie's Avatar
Default Aye ... Questions On Setting Up New Engine! :)
Hey Guys, picked up a nice EB/D 6 cylinder MPFI for my EA Series 1, now, we is taking out:
a) the CFI Blown Engine
b) the wiring for it
c) the 3 Speed Box
d) the ECU
and is replacing it with
a) new EB/D engine
b) 4 Speed Box
c) transmission loom from a EBII
d) engine bay loom from a EBII
e) ecu loom from a EBII
now will this be fine?, eg the engine bay looms from this EBII n will they into my new ecu that i get, and any recommendations wot ECU, like will a EBII engine loom need a EBII/ED ECU ? ... same as the ECU Loom, does it only go into a EBII ECU...remember i have a Series 1 EA Fairmont CFI but am taking everything out.
Thanks
-Grechie
Grechie is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2005, 07:53 PM   #2
LUXO_8
windsor user
talk to dellboy with regards to fitting the 4 speed box...
the chassis rails are different between the 3 speed and 4 speed (different mounting position for the trans mount)
Old 28-05-2005, 08:42 PM   #3
NZ
NZ's Avatar
I'd say make it a 5 speed if your going to all this trouble. if you were only making it multipoint you could just leave the current looms there and just put the multipoint computer in. you do realise if you end up with a smartlock ecu you will need to practically do whe wiring in the whole car? your dash loom wont have a hope in hell of plugging up to the power loom, and you need the power loom from a 4 speed to run the trans. theres a lot more in this that you probably realise man.
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
Old 28-05-2005, 08:55 PM   #4
InitialD
Low and Loud
InitialD's Avatar
For EB2 Wiring to be installed in your car you have to rewire the entire car and you dont need it as you can use EA wiring as ive told you many times. Why waste your time, put a T5 in
Old 29-05-2005, 10:54 AM   #5
galapogos01
eec tweaker
galapogos01's Avatar
if you want an auto, get an EAII ECU loom & ECU so you have the seperate trans controller. dont **** around with smartlock and the integrated ecu.
galapogos01 is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2005, 05:15 PM   #6
INJECTED_250
Custom user title
INJECTED_250's Avatar
T5 t 5 t5 t5 t5 t5 t5 t5 t5 t5 t5 t5 can ya say t5
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2005, 07:48 PM   #7
neb
hibernating
neb's Avatar
agreed.... t5... you know you want to grechie
neb is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2005, 08:18 PM   #8
Damo
how is it that changing from 3 speed to 4 speed you need different trans mount point. But changing from 3-5 or 4-5 speed you don't...
I say go the 5 speed too. Just remember that you'll also need manual flywheel, clutch, pedal box, clutch cable, spigot bearing, clutch release thingo + cleavis bushes, bandaids, headache tablets, valium.. err yeah! and patience.
Oh and a clutch allignment tool that comes with insturctions and actually fits the Falcon.
Good luck with it all.
